Is it possible to edit the tab header in place
Hi again,
Please look at my latest post, form the 30th of May, where I have provided you with a better approach on the matter, that doesn’t require retemplating.
Let me know if you have any concerns about it in particular.
hi ,
from the below code can u please tell me what are the changes i have to do for to edit the tab in place
="GuiControls.View.TabView"
="http://schemas.syncfusion.com/wpf"
="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
="http://schemas.microsoft.com/winfx/2006/xaml"
="clr-namespace:GuiControls.Controls"
="Auto"
="clr-namespace:GuiControls.ViewModel"
="http://infragistics.com/Editors"
="http://infragistics.com/Windows">
="6" />
="22" />
="2" />
Name
AllowTabClosing
="True"
ShowTabHeaderCloseButton
="2">
="Template">
="true">
Border
="Bd"
="1,1,1,0"
="3,3,0,0">
<!--Substitute the ContentPresenter with a XamTextEditor-->
="tbEdit_PreviewMouseDoubleClick"
="Transparent"
="tbEdit_EditModeStarting"
="tbEdit_EditModeEnding"
="Highlight"
="3"
="3,3,0,0"
.TabItemHottrackHighlightLightFillKey}}"
.TabItemHottrackHighlightDarkFillKey}}"
="Collapsed"
="Top"/>
CloseButtonVisibility
="WhenSelectedOrHotTracked">
I looked into your snippet and when I tested it out I noticed that a whole TabItem is paced inside the tab header, so actually my previous assumption was a bit off. The ItemTemplate isexatly what you are looking for – it sets the visual tree for the TabItemEx’s header and you can set it like so:
<igWindows:XamTabControl Name="xamTabControl1" >
<igWindows:XamTabControl.ItemTemplate>
<DataTemplate>
<TextBox Text="{Binding Header}"/>
</DataTemplate>
</igWindows:XamTabControl.ItemTemplate>...
Also you can take a look at the ContentTemplate property which sets the visual tree for the content area of the TabItemEx.
Please let me know if I can be of any further assistance on the matter.
actually we are binding the xamtabcontrol as below
<igWindows:XamTabControl Name="xamTabControl1" TabLayoutStyle="MultiRowSizeToFit" MaximumTabRows="4" MaximumSizeToFitAdjustment="50" MinimumTabExtent="100" InterTabSpacing="2" InterRowSpacing="2" AllowTabClosing="True" ShowTabHeaderCloseButton="True" TabItemCloseButtonVisibility="WhenSelectedOrHotTracked" ItemsSource="{Binding Path=SimulationTabs }" > <igWindows:XamTabControl.ItemTemplate> <DataTemplate> <TabItem Header="{Binding Path=Header}" /> </DataTemplate> </igWindows:XamTabControl.ItemTemplate> <ContextMenuService.ContextMenu> <ContextMenu Name="tabContextMenu"> <MenuItem Header="Close" Command="{Binding Path=CloseCommand}" ></MenuItem> <MenuItem Header="Delete" Command="{Binding Path=DeleteCommand}"></MenuItem> </ContextMenu> </ContextMenuService.ContextMenu> </igWindows:XamTabControl>
we are not using any TabItemEx’s so let me know how to enable the tabitem header editable in place.
