3160
Pivot grid crashes if hierarchy and level have the same name
Please see FlatDataExample.xaml.cs in the attached project.
Note this section:
     // Crashes here if hierarchies and levels have the same name.
            // However, changing names causes hierarchies not to display in pivot grid.
            PeopleGrid.DataSource.Filters.Add(PeopleGrid.DataSource.CreateFilterViewModel(
                PeopleGrid.DataSource.Cube.Dimensions["Gender"].Hierarchies.First()));
                PeopleGrid.DataSource.Cube.Dimensions["TypeCode"].Hierarchies.First()));
I've tried changing the hierarchy and level names however when I do that the pivot grid does not display any dimenions.
The code below is a WORKING page from a different project that is running the same version of Infragistics (I checked each dll).
Why does it work?
 <igFlatData:FlatDataSource x:Key="RollBookDataSource" x:Shared="False"
                                   Rows="[PIMCO_DESC].[Product],[BROKER].[Broker]"
                                   Columns="[Measure].[Measure]"
                                   Measures="Long,Short,Net">
            <igFlatData:FlatDataSource.ConnectionSettings>
                <igFlatData:FlatDataConnectionSettings ItemsSource="{Binding}"/>
            </igFlatData:FlatDataSource.ConnectionSettings>
            <igFlatData:FlatDataSource.CubesSettings>
                <igFlatData:CubeMetadata DataTypeFullName="Poolman.Models.TBARollPivotItem">
                    <igFlatData:DimensionMetadata SourcePropertyName="Long"
                                                  DisplayFormat="{}{0:#,#;(#,#)}"/>
                    <igFlatData:DimensionMetadata SourcePropertyName="Short"
                    <igFlatData:DimensionMetadata SourcePropertyName="Net"
                </igFlatData:CubeMetadata>
            </igFlatData:FlatDataSource.CubesSettings>
            <igFlatData:FlatDataSource.HierarchyDescriptors>
                <igFlatData:HierarchyDescriptor SourcePropertyName="{x:Static local:TBARollBook.kMeasure}">
                    <igFlatData:HierarchyDescriptor.LevelDescriptors>
                        <igFlatData:HierarchyLevelDescriptor LevelName="Type"
                                                             LevelExpressionPath="Measure.Type"/>
                    </igFlatData:HierarchyDescriptor.LevelDescriptors>
                </igFlatData:HierarchyDescriptor>
                <igFlatData:HierarchyDescriptor SourcePropertyName="PM_NAME"
                                                HierarchyName="{x:Static local:TBARollBook.kFilterPM}">
                        <igFlatData:HierarchyLevelDescriptor LevelName="All"/>
                        <igFlatData:HierarchyLevelDescriptor LevelName="PM"
                                                             LevelExpressionPath="PM_NAME"/>
                <igFlatData:HierarchyDescriptor SourcePropertyName="DELIVERY_DT"
                                                HierarchyName="{x:Static local:TBARollBook.kFilterDelivery}">
                        <igFlatData:HierarchyLevelDescriptor LevelName="Delivery"
                                                             LevelExpressionPath="DELIVERY_DT"/>
                <igFlatData:HierarchyDescriptor SourcePropertyName="ROLL_IND"
                                                HierarchyName="{x:Static local:TBARollBook.kFilterRoll}">
                        <igFlatData:HierarchyLevelDescriptor LevelName="Roll"
                                                             LevelExpressionPath="ROLL_IND"/>
                <igFlatData:HierarchyDescriptor SourcePropertyName="TURN_IND"
                                                HierarchyName="{x:Static local:TBARollBook.kFilterTurn}">
                        <igFlatData:HierarchyLevelDescriptor LevelName="Turn"
                                                             LevelExpressionPath="TURN_IND"/>
                <igFlatData:HierarchyDescriptor SourcePropertyName="PIMCO_DESC"
                                                HierarchyName="{x:Static local:TBARollBook.kViewProduct}">
                        <igFlatData:HierarchyLevelDescriptor LevelName="Product"
                                                             LevelExpressionPath="PIMCO_DESC"/>
                <igFlatData:HierarchyDescriptor SourcePropertyName="BROKER"
                                                HierarchyName="{x:Static local:TBARollBook.kViewBroker}">
                        <igFlatData:HierarchyLevelDescriptor LevelName="Broker"
                                                             LevelExpressionPath="BROKER"/>
            </igFlatData:FlatDataSource.HierarchyDescriptors>
        </igFlatData:FlatDataSource>
   RollGrid.DataSource.Filters.Add(RollGrid.DataSource.CreateFilterViewModel(
                RollGrid.DataSource.Cube.Dimensions["PM_NAME"].Hierarchies.First()));
            FilterPM();
                RollGrid.DataSource.Cube.Dimensions["DELIVERY_DT"].Hierarchies.First()));
            FilterDelivery();
                RollGrid.DataSource.Cube.Dimensions["TURN_IND"].Hierarchies.First()));
            FilterTurn();
                RollGrid.DataSource.Cube.Dimensions["ROLL_IND"].Hierarchies.First()));
            FilterRoll();
PivotGridTest.zip
  • 3160
    posted in reply to [Infragistics] Plamen Pilev
    Plamen I found it thanks to your example.  I was not wiring up the herarchy changed event inside the ExpandDimensions method.
    private void ExpandDimensions()
     PeopleGrid.DataSource.ResultChanged += FilterHelper.HierarchyChanged;
    public void HierarchyChanged(object sender, AsyncCompletedEventArgs e)
                DataSourceBase dataSourceBase = (DataSourceBase)sender;
                dataSourceBase.ResultChanged -= HierarchyChanged;
                dataSourceBase.HierarchyExpansionMode = HierarchyExpansionMode.DrillDown;
                dataSourceBase.UpdateVisualMembers(Infragistics.Olap.ExecutionContext.Rows);
                dataSourceBase.UpdateVisualMembers(Infragistics.Olap.ExecutionContext.Columns);
                dataSourceBase.HierarchyExpansionMode = HierarchyExpansionMode.SingleLevelOnly;
                dataSourceBase.RefreshGrid();
  • 3160
    Hi Plamen,  The following is code from a working page from our project.  I will look at the changes you posted on the other thread.
     using System;
    using System.Collections.Generic;
    using System.Linq;
    using System.Text;
    using System.Windows;
    using System.Windows.Controls;
    using System.Windows.Data;
    using System.Windows.Documents;
    using System.Windows.Input;
    using System.Windows.Media;
    using System.Windows.Media.Imaging;
    using System.Windows.Navigation;
    using System.Windows.Shapes;
    using Infragistics.Olap.FlatData;
    using Infragistics.Olap;
    using Infragistics.Olap.Data;
    using System.Threading;
    using Poolman.Models;
    using Infragistics.Controls.Grids;
    using System.ComponentModel;
    using Poolman.Entities;
    using System.Collections.ObjectModel;
    using System.Linq.Expressions;
    using Poolman.Common;
    namespace Poolman.Views
        public partial class TBARollBook : UserControl
            public TBARollBookViewModel ViewModel
                get { return (TBARollBookViewModel)DataContext; }
            private ManualResetEvent _mre;
            private bool RollBookLoaded;
            /* we are using the built in filter/hierarchy   *
             * mechanisms of the XamPivotGrid which require *
             * using some magic strings which correspond to *
             * properties shown in the control              */
            public static string kViewProduct    = "Product";
            public static string kViewBroker     = "Broker";
            public static string kViewAccount    = "Account";
            public static string kBookLast       = "As of Last Close";
            public static string kBookLive       = "Live";
            public static string kBookMust       = "Must Roll";
            public static string kFilterRoll     = "Roll";
            public static string kFilterDelivery = "Delivery";
            public static string kFilterPM       = "PM";
            public static string kFilterTurn     = "Turn";
            public static string kFilterFail     = "Fail";
            public static string kMeasure        = "Measure";
            public TBARollBook()
                InitializeComponent();
                RollBookLoaded = false;
                this.DataContext = new TBARollBookViewModel();
                Loaded += new RoutedEventHandler(TBARollBook_Loaded);
                Dispatcher.ShutdownStarted += (s, e) => OnSaveLayout(User.CurrentUser.APP_LAYOUT);
            void TBARollBook_Loaded(object sender, RoutedEventArgs e)
                Loaded -= new RoutedEventHandler(TBARollBook_Loaded);
                OnRestoreLayout(User.CurrentUser.APP_LAYOUT);
            private void LoadRollBook()
                RollGrid.DataSource = (IOlapViewModel)FindResource("RollBookDataSource");
                ((FlatDataSource)RollGrid.DataSource).ItemsSource = ViewModel.RollBook;
                RollGrid.DataSource.ResultChanged += OnResultChanged;
                // Bug in Infragistics version 11.1 - sort expressions do not work. - see the following thread.
    http://community.infragistics.com/forums/p/65104/329867.aspx#329867
                //System.Linq.Expressions.Expression<Func<TBARollPivotItem, string>> sortCusip = x => new Random().Next().ToString();
                //System.Linq.Expressions.Expression<Func<TBARollPivotItem, string>> sortBroker = x => x.Position.BROKER;
                //source.HierarchyDescriptors[6].LevelDescriptors[1].OrderByKeyExpression = sortCusip;
                //source.HierarchyDescriptors[6].LevelDescriptors[2].OrderByKeyExpression = sortBroker;
                //source.HierarchyDescriptors[7].LevelDescriptors[1].OrderByKeyExpression = sortBroker;
                FilterPM();
                FilterDelivery();
                FilterTurn();
                FilterRoll();
                /* populate combo boxes with distinct values from filter */
                ViewModel.DeliveryDates = new List<string> { "All", "All Failing" }.Union(
                    from p in ViewModel.RollBook
                    orderby p.Position.DELIVERY_DT
                    select p.DELIVERY_DT).Distinct().ToList();
                /* set default book */
                FilterBook();
                /* set default view */
                FilterView();
                //ViewModel.PropertyChanged += ViewModelPropertyChanged;
                RollBookLoaded = true;
            private void ViewModelPropertyChanged(object sender, PropertyChangedEventArgs e)
                if (e.PropertyName == "RollBook")
                    Dispatcher.BeginInvoke(new Action(delegate()
                        LoadRollBook();
            private void OnResultChanged(object sender, AsyncCompletedEventArgs e)
                FlatDataSource fds = (FlatDataSource)RollGrid.DataSource;
                List<TBARollPosition> ResultPositions = new List<TBARollPosition>();
                List<int> indices = fds.GetCellItemsIndexes(
                    fds.Result.Cells[fds.Result.Cells.GetUpperBound(0), fds.Result.Cells.GetUpperBound(1)]);
                foreach (int index in indices)
                    ResultPositions.Add(((TBARollPivotItem)fds.GetRecord(index)).Position);
                ViewModel.ResultPositions = new ObservableCollection<TBARollPosition>(ResultPositions);
            private void OnLoaded(object sender, RoutedEventArgs e)
                if (!RollBookLoaded)
                    LoadRollBook();
                    /* hide some filters of the XamPivotGrid which are set in code */
                    RollGrid.MeasuresDropControl.Visibility = Visibility.Collapsed;
                    RollGrid.ColumnsDropControl.Visibility = Visibility.Collapsed;
                    RollGrid.FiltersDropControl.Visibility = Visibility.Collapsed;
                    /* default filter Options = All */
                    ViewModel.SelectedPMs = "All";
                    ViewModel.SelectedDelivery = "All";
                    /* for convenience set Delivery Date to nearest pool day */
                    ViewModel.SelectedDelivery = String.Format("{0:MM/dd/yyyy}", ViewModel.DeliveryDates
                    .Where(x => !x.Contains("All") && Convert.ToDateTime(x) > DateTime.Now.Date && Common.Utilities.GetBusinessDays(DateTime.Now, Convert.ToDateTime(x)) > 2)
                    .Min(x => Convert.ToDateTime(x)));
            private IFilterViewModel GetFilterViewModel(FlatDataSource source, string caption)
                foreach (var filter in source.Filters)
                    if (filter.Caption == caption)
                        return (IFilterViewModel)filter;
                foreach (var row in source.Rows)
                    if (row.Caption == caption)
                        return (IFilterViewModel)row;
                foreach (var column in source.Columns)
                    if (column.Caption == caption)
                        return (IFilterViewModel)column;
                return null;
            private void ExpandHierarchy(IFilterMember filter, bool value)
                _mre = new ManualResetEvent(false);
                if (filter.IsExpanded != value)
                    filter.IsExpanded = value;
                if (filter.FilterMembers == null)
                    _mre.WaitOne();
                foreach (var child in filter.FilterMembers)
                    ExpandHierarchy(child, value);
            private void SetFilter(IFilterMember filter, string value, bool set)
                if (filter.Caption == value)
                    filter.IsSelected = set;
                /* expand the filter if closed */
                if (!filter.IsExpanded)
                    filter.IsExpanded = true;
                    _mre.WaitOne();
                    SetFilter(child, value, set);
            private void OnPMChanged(object sender, SelectionChangedEventArgs e)
                //ViewModel.SelectedPMs = PMFilter.SelectedItems.Cast<PortfolioManager>().ToList();
                FilterPM();
                RollGrid.DataSource.RefreshGrid();
            private void OnDeliveryChanged(object sender, SelectionChangedEventArgs e)
                FilterDelivery();
            private void FilterPM()
                //if (ViewModel.SelectedPMs.Count > 0)
                //    FilterOption(kFilterPM, "All", false);
                //    foreach (var pm in ViewModel.SelectedPMs)
                //        FilterOption(kFilterPM, pm.Name);
                //else
                //    FilterOption(kFilterPM, "All");
                if (ViewModel.SelectedPMs != null)
                    foreach (var pm in ViewModel.SelectedPMs.Split('\\'))
                        FilterOption(kFilterPM, pm);
            private void FilterDelivery()
                FilterOption(kFilterDelivery, "All", false);
                if (ViewModel.SelectedDelivery == "All Failing")
                    ViewModel.IsNetFails = false;
                    NetFails.IsEnabled = false;
                    foreach (var date in ViewModel.DeliveryDates)
                        if (!date.Contains("All") && Convert.ToDateTime(date) < DateTime.Today)
                            FilterOption(kFilterDelivery, date);
                else
                    NetFails.IsEnabled = true;
                    FilterOption(kFilterDelivery, ViewModel.SelectedDelivery);
            private void FilterOption(string tag, string value, bool set=true)
                IFilterViewModel fvm = GetFilterViewModel(
                    (FlatDataSource)RollGrid.DataSource, tag);
                fvm.LoadFilterMembersCompleted +=
                    (s, e) => _mre.Set();
                if (fvm.FilterMembers != null)
                    foreach (var filter in fvm.FilterMembers)
                        SetFilter(filter, value, set);
                fvm.CommitChanges();
            private void OnBookChanged(object sender, RoutedEventArgs e)
                FilterBook();
            private void FilterBook()
                    (FlatDataSource)RollGrid.DataSource, kMeasure);
                    if (filter.Caption == kBookLast)
                        filter.IsSelected = ViewModel.IsLastRoll;
                    if (filter.Caption == kBookLive)
                        filter.IsSelected = ViewModel.IsLiveRoll;
                    if (filter.Caption == kBookMust)
                        filter.IsSelected = ViewModel.IsMustRoll;
            private void OnViewChanged(object sender, RoutedEventArgs e)
                FilterView();
            private void FilterView()
                RollGrid.DataSource.DeferredLayoutUpdate = true;
                FlatDataSource source = (FlatDataSource)RollGrid.DataSource;
                IFilterViewModel product = GetFilterViewModel(source, kViewProduct);
                product.LoadFilterMembersCompleted += (s, e) => _mre.Set();
                foreach (IFilterMember member in product.FilterMembers)
                    ExpandHierarchy(member, true);
                IFilterViewModel broker = GetFilterViewModel(source, kViewBroker);
                broker.LoadFilterMembersCompleted += (s, e) => _mre.Set();
                foreach (IFilterMember member in broker.FilterMembers)
                    ExpandHierarchy(member, ViewModel.IsBrokerView);
                RollGrid.DataSource.ResultChanged += HierarchyChanged;
                RollGrid.DataSource.DeferredLayoutUpdate = false;
                RollGrid.Visibility = ViewModel.IsAccountView ? Visibility.Collapsed : Visibility.Visible;
                AccountGrid.Visibility = ViewModel.IsAccountView ? Visibility.Visible : Visibility.Collapsed;
            private void HierarchyChanged(object sender, AsyncCompletedEventArgs e)
            private void OnRollChanged(object sender, RoutedEventArgs e)
                FilterRoll();
            private void FilterRoll()
                    (FlatDataSource)RollGrid.DataSource, kFilterRoll);
                    if (filter.Caption == "N")
                        filter.IsSelected = ViewModel.IsRollAll;
            private void OnTurnChanged(object sender, RoutedEventArgs e)
                FilterTurn();
            private void FilterTurn()
                    (FlatDataSource)RollGrid.DataSource, kFilterTurn);
                    if (filter.Caption == "Y")
                        filter.IsSelected = ViewModel.IsTurnYes;
                        filter.IsSelected = ViewModel.IsTurnNo;
            private void OnFailsChanged(object sender, RoutedEventArgs e)
                ViewModel.BuildRollBook();
                LoadRollBook();
            private void OnDrillDown(object sender, PivotCellClickedEventArgs e)
                ViewModel.RollDrillDown.Clear();
                ICell cell = (ICell)RollGrid.ActiveCell.Data;
                if (cell != null)
                    List<int> indices = fds.GetCellItemsIndexes(cell);
                        TBARollPivotItem item = (TBARollPivotItem)fds.GetRecord(index);
                        if (item.Net != 0)
                            ViewModel.RollDrillDown.Add(item);
                ViewModel.TBADrillDown = RollGrid.ActiveCell.DataRow.Tuple.Members[0].Name
                    + " (" + RollGrid.ActiveCell.DataColumn.Tuple.Members[0].Name + ")";
                TBARollDrillDown window = new TBARollDrillDown(ViewModel);
                window.Owner = Application.Current.MainWindow;
                window.WindowStartupLocation = WindowStartupLocation.CenterOwner;
                window.ShowDialog();
            private void OnRefresh(object sender, RoutedEventArgs e)
                ViewModel.Refresh();
                LoadRollBook();
            private void ExcelButton_Click(object sender, RoutedEventArgs e)
                string filePath = "";
                if (ViewModel.IsAccountView)
                    filePath = Common.Utilities.GetUniqueFileName(System.IO.Path.Combine(Environment.GetFolderPath(Environment.SpecialFolder.LocalApplicationData), "TBARollBookAccounts.xlsx"));
                    Common.Utilities.ExportGridAsync(AccountGrid, filePath);
                else
                    if(ViewModel.IsBrokerView)
                        filePath = Common.Utilities.GetUniqueFileName(System.IO.Path.Combine(Environment.GetFolderPath(Environment.SpecialFolder.LocalApplicationData), "TBARollBookBrokers.xls"));
                    else
                        filePath = Common.Utilities.GetUniqueFileName(System.IO.Path.Combine(Environment.GetFolderPath(Environment.SpecialFolder.LocalApplicationData), "TBARollBookProducts.xls"));
                    Common.PivotGridExporter exporter = new Common.PivotGridExporter();
                    exporter.ExportToExcel(RollGrid, filePath, true, true);
            public void OnSaveLayout(AppLayout layout)
                layout.TBARollBookLayout = AccountGrid.SaveCustomizations();
            public void OnRestoreLayout(AppLayout layout)
                if (!string.IsNullOrWhiteSpace(layout.TBARollBookLayout))
                    AccountGrid.LoadCustomizations(layout.TBARollBookLayout);
            private void OnCellRightClicked(object sender, Behaviors.CellRightClickedEventArgs e)
                // Cell will be null if it is a row or column header cell.
                PivotCell cell = null;
                if (e.Cell != null)
                    cell = (PivotCell)e.Cell.Cell;
                    if(RollGrid.ActiveCell != null)
                        RollGrid.ActiveCell.IsSelected = false;
                    RollGrid.ActiveCell = cell;
                    RollGrid.ActiveCell.IsSelected = true;
                ViewModel.MouseOverCell = cell;
    <UserControl x:Class="Poolman.Views.TBARollBook"
                 xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
                 xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
                 xmlns:igPivot="http://schemas.infragistics.com/xaml"
                 xmlns:igFlatData="http://schemas.infragistics.com/olap"
                 xmlns:igDP="http://infragistics.com/DataPresenter"
                 xmlns:igExt="clr-namespace:PIMCO.Infra.Extensions;assembly=PIMCO.Infragistics.Extensions"
                 xmlns:local="clr-namespace:Poolman.Views"
                 xmlns:ig="http://schemas.infragistics.com/xaml"
                 xmlns:i="http://schemas.microsoft.com/expression/2010/interactivity"
                 xmlns:Behaviors="clr-namespace:Poolman.Behaviors"
                 xmlns:localControls="clr-namespace:Poolman.Controls">
        <UserControl.Resources>
            <Style x:Key="ShortStyle" TargetType="{x:Type igPivot:PivotCellControl}"
                   BasedOn="{StaticResource PivotCellStyle}">
                <Style.Triggers>
                    <DataTrigger Binding="{Binding RelativeSource={RelativeSource Self}, Path=Cell.Data.Value,
                        Converter={StaticResource IsNegative}}" Value="True">
                        <Setter Property="Foreground" Value="Red"/>
                    </DataTrigger>
                </Style.Triggers>
                <Setter Property="HorizontalContentAlignment" Value="Right"/>
                <Setter Property="FontFamily" Value="Calibri"/>
                <Setter Property="FontSize" Value="13"/>
            </Style>
            <Style x:Key="TotalRowCellStyle" TargetType="{x:Type igPivot:PivotCellControl}"
                   BasedOn="{StaticResource ShortStyle}">
                <Setter Property="Background" Value="#444444"/>
            </Style>
            <Style x:Key="CellStyle" TargetType="igPivot:PivotCellControl" BasedOn="{StaticResource ShortStyle}">
                <Setter Property="Background" Value="#222222"/>
            </Style>
            <Style x:Key="TotalCellStyle" TargetType="igPivot:PivotCellControl" BasedOn="{StaticResource TotalRowCellStyle}">
                <Setter Property="Background">
                <Setter.Value>
                        <LinearGradientBrush EndPoint="0.5,1" StartPoint="0.5,0">
                            <GradientStop Color="#B2D6D6D6" Offset="1"/>
                            <GradientStop Color="#B2E7E7E7" Offset="0"/>
                        </LinearGradientBrush>
                    </Setter.Value>
                </Setter>
            </Style>
        </UserControl.Resources>
        <Grid>
            <Grid.RowDefinitions>
                <RowDefinition Height="Auto"/>
                <RowDefinition Height="*"/>
            </Grid.RowDefinitions>
            <localControls:Toolbar/>
            <StackPanel Grid.Row="0" Orientation="Horizontal">
                <StackPanel.Resources>
                    <Style TargetType="{x:Type GroupBox}">
                        <Setter Property="Margin" Value="2"/>
                    </Style>
                </StackPanel.Resources>
                <GroupBox Header="Options" Foreground="White"
                          Template="{DynamicResource MainGroupBoxControlTemplate}">
                    <StackPanel Orientation="Horizontal">
                        <Grid>
                            <Grid.ColumnDefinitions>
                                <ColumnDefinition Width="Auto"/>
                            </Grid.ColumnDefinitions>
                            <Grid.Resources>
                                <Style TargetType="{x:Type ComboBox}">
                                    <Setter Property="Width" Value="150"/>
                                    <Setter Property="Margin" Value="4"/>
                                    <Setter Property="VerticalAlignment" Value="Center"/>
                                </Style>
                                <Style TargetType="{x:Type TextBlock}" BasedOn="{StaticResource {x:Type TextBlock}}">
                                </Style>
                            </Grid.Resources>
                            <TextBlock Text="Delivery Date" Grid.Row="0" Grid.Column="0"/>
                            <ComboBox Grid.Row="0" Grid.Column="1"
                                      ItemsSource="{Binding DeliveryDates}"
                                      SelectionChanged="OnDeliveryChanged"
                                      SelectedItem="{Binding SelectedDelivery}"/>
                            <TextBlock Text="Portfolio Manager" Grid.Row="1" Grid.Column="0" Width="100"/>
                            <ComboBox Grid.Row="1" Grid.Column="1"
                                      ItemsSource="{Binding PortfolioManagers}"
                                      SelectionChanged="OnPMChanged"
                                      SelectedItem="{Binding SelectedPMs}"/>
                            <!--<ig:XamMultiColumnComboEditor Name="PMFilter" Grid.Row="1" Grid.Column="1"
                                                          EmptyText="All"
                                                          DisplayMemberPath="Name"
                                                          AllowDropDownResizing="True"
                                                          AllowMultipleSelection="True"
                                                          CheckBoxVisibility="Visible"
                                                          SelectedItemsResetButtonVisibility="Visible"
                                                          Margin="4" Width="150">
                                <ig:XamMultiColumnComboEditor.Columns>
                                    <ig:TextComboColumn Key="Name" HeaderText="PM"/>
                                </ig:XamMultiColumnComboEditor.Columns>
                            </ig:XamMultiColumnComboEditor>-->
                            <CheckBox IsChecked="{Binding IsRollAll}"
                                      Content="Include Do Not Roll"
                                      Click="OnRollChanged"
                                      Style="{StaticResource PoolmanCB}"
                                      Grid.Row="1" Grid.Column="2"/>
                            <CheckBox Name="NetFails"
                                      IsChecked="{Binding IsNetFails}"
                                      Content="Include Failing Positions"
                                      Click="OnFailsChanged"
                                      Grid.Row="0" Grid.Column="2"/>
                        </Grid>
                    </StackPanel>
                </GroupBox>
                <GroupBox Header="Book" Foreground="White"
                    <StackPanel>
                        <CheckBox IsChecked="{Binding IsLastRoll}"
                                  Content="{x:Static local:TBARollBook.kBookLast}"
                                  Click="OnBookChanged"
                                  IsEnabled="False"/>
                        <CheckBox IsChecked="{Binding IsLiveRoll}"
                                  Content="{x:Static local:TBARollBook.kBookLive}"
                                  Style="{StaticResource PoolmanCB}"/>
                        <CheckBox IsChecked="{Binding IsMustRoll}"
                                  Content="{x:Static local:TBARollBook.kBookMust}"
                    </StackPanel>
                </GroupBox>
                <GroupBox Header="View" Foreground="White"
                    <StackPanel>
                            <Style TargetType="{x:Type RadioButton}">
                                <Setter Property="Foreground" Value="White"/>
                            </Style>
                        <RadioButton IsChecked="{Binding IsProductView}"
                                     GroupName="View"
                                     Content="Product"
                                     Tag="{x:Static local:TBARollBook.kViewProduct}"
                                     Click="OnViewChanged"/>
                        <RadioButton IsChecked="{Binding IsBrokerView}"
                                     GroupName="View"
                                     Content="Broker"
                                     Tag="{x:Static local:TBARollBook.kViewBroker}"
                        <RadioButton IsChecked="{Binding IsAccountView}"
                                     GroupName="View"
                                     Content="Account"
                                     Tag="{x:Static local:TBARollBook.kViewAccount}"
                    </StackPanel>
                </GroupBox>
                <GroupBox Header="Turn" Foreground="White"
                    <StackPanel>
                        <CheckBox IsChecked="{Binding IsTurnYes}"
                                  Content="Yes"
                                  Click="OnTurnChanged"
                        <CheckBox IsChecked="{Binding IsTurnNo}"
                                  Content="No"
                    </StackPanel>
                </GroupBox>
                        <Style TargetType="{x:Type Button}" BasedOn="{StaticResource ChromelessButton}">
                            <Setter Property="VerticalAlignment" Value="Bottom"/>
                            <Setter Property="Width" Value="46"/>
                        </Style>
                    <Button Click="OnRefresh">
                        <StackPanel>
                            <Image Source="..\Images\refresh.ico" Style="{DynamicResource SmallImage}"/>
                            <TextBlock Text="Refresh" Style="{DynamicResource ChromelessButtonLabel}"/>
                        </StackPanel>
                    </Button>
                    <Button Click="ExcelButton_Click">
                        <StackPanel>
                            <Image Source="..\Images\excel.png" Style="{DynamicResource SmallImage}"/>
                            <TextBlock Text="Excel" Style="{DynamicResource ChromelessButtonLabel}"/>
                        </StackPanel>
                    </Button>
                </StackPanel>
            </StackPanel>
            <igPivot:XamPivotGrid Name="RollGrid"
                                  Grid.Row="1"
                                  AllowCompactLayout="True"
                                  Loaded="OnLoaded"
                                  CellDoubleClicked="OnDrillDown"
                                  TotalRowStyle="{StaticResource TotalRowCellStyle}"
                                  CellStyle="{StaticResource ShortStyle}"
                                  DataSource="{StaticResource RollBookDataSource}"
                                  BorderBrush="{x:Null}"
                                  BorderThickness="0">
                <i:Interaction.Behaviors>
                    <Behaviors:PivotCellColorBehavior ItemsSource="{Binding BrokerColors}" ForegroundColor="White"/>
                        <Behaviors:PivotGridAutoWidthBehavior/>
                        <Behaviors:SectionShaderBehavior ColumnName="Live" CellStyle="{StaticResource CellStyle}"
                                                         TotalCellStyle="{StaticResource TotalCellStyle}"/>
                    <Behaviors:PivotGridMouseOverCellBehavior ClickRightClicked="OnCellRightClicked"/>
                </i:Interaction.Behaviors>
                <igPivot:XamPivotGrid.SelectionSettings>
                    <igPivot:PivotSelectionSettings RowSelection="None"
                                                    ColumnSelection="None"/>
                </igPivot:XamPivotGrid.SelectionSettings>
                <igPivot:XamPivotGrid.ContextMenu>
                    <ContextMenu>
                        <MenuItem Header="Send to Execution"
                                  Command="{Binding ContextMenuCommand}">
                            <MenuItem.Icon>
                                <Image Width="16" Height="16" Source="../Images/upload.ico"/>
                            </MenuItem.Icon>
                        </MenuItem>
                    </ContextMenu>
                </igPivot:XamPivotGrid.ContextMenu>
            </igPivot:XamPivotGrid>
            <igDP:XamDataGrid Name="AccountGrid"
                              Grid.Row="1"
                              Visibility="Collapsed"
                              DataSource="{Binding ResultPositions}"
                              GroupByAreaLocation="None"
                              AutoFit="False">
                <igDP:XamDataGrid.FieldSettings>
                    <igDP:FieldSettings AllowEdit="False"
                                        AllowRecordFiltering="True"
                                        FilterLabelIconDropDownType="MultiSelectExcelStyle"
                                        SummaryDisplayArea="BottomFixed"
                                        CellClickAction="SelectRecord"/>
                </igDP:XamDataGrid.FieldSettings>
                <igDP:XamDataGrid.FieldLayoutSettings>
                    <igDP:FieldLayoutSettings
                        AutoFitMode="ExtendLastField"
                        AllowDelete="False"
                        AllowAddNew="False"
                        AllowFieldMoving="WithinLogicalRow"
                        AutoGenerateFields="False"
                        HighlightAlternateRecords="True"
                        RecordSelectorLocation="None"
                        FilterUIType="LabelIcons"/>
                </igDP:XamDataGrid.FieldLayoutSettings>
                <igDP:XamDataGrid.FieldLayouts>
                    <igDP:FieldLayout>
                        <igDP:FieldLayout.SortedFields>
                            <igDP:FieldSortDescription
                                Direction="Ascending"
                                FieldName="ACCT_NO"/>
                        </igDP:FieldLayout.SortedFields>
                        <igDP:FieldLayout.Fields>
                            <igDP:Field Name="DELIVERY_DT" Label="Delivery"/>
                            <igDP:Field Name="ACCT_NO" Label="Account">
                                <igDP:Field.Settings>
                                    <igDP:FieldSettings EditorStyle="{StaticResource PoolmanDecimalStyle}"/>
                                </igDP:Field.Settings>
                            </igDP:Field>
                            <igDP:Field Name="PM_NAME" Label="PM"/>
                            <igDP:Field Name="PIMCO_DESC" Label="Security"/>
                            <igDP:Field Name="BROKER" Label="Broker">
                                    <igDP:FieldSettings CellValuePresenterStyle="{StaticResource BrokerCell}"/>
                            </igDP:Field>
                            <igDP:Field Name="LONG_QTY" Label="Long">
                                    <igDP:FieldSettings EditorStyle="{StaticResource AmountStyle}"/>
                            </igDP:Field>
                            <igDP:Field Name="SHORT_QTY" Label="Short">
                            </igDP:Field>
                            <igDP:Field Name="Net">
                            </igDP:Field>
                            <igDP:Field Name="LIVE_LONG_QTY" Label="Long (Live)">
                            </igDP:Field>
                            <igDP:Field Name="LIVE_SHORT_QTY" Label="Short (Live)">
                            </igDP:Field>
                            <igDP:Field Name="LiveNet" Label="Net (Live)">
                            </igDP:Field>
                            <igDP:Field Name="MUST_ROLL_LONG_QTY" Label="Long (Must Roll)">
                            </igDP:Field>
                            <igDP:Field Name="MUST_ROLL_SHORT_QTY" Label="Short (Must Roll)">
                            </igDP:Field>
                            <igDP:Field Name="MustRollNet" Label="Net (Must Roll)">
                            </igDP:Field>
                            <igDP:Field Name="ROLL_IND" Label="Roll"/>
                            <igDP:Field Name="TURN_IND" Label="Turn"/>
                            <igDP:Field Name="TKD_IND" Label="TKD"/>
                        </igDP:FieldLayout.Fields>
                        <igDP:FieldLayout.SummaryDefinitions>
                            <igDP:SummaryDefinition SourceFieldName="LONG_QTY"
                                                    Calculator="Sum"
                                                    StringFormat="{}{0:#,#;(#,#)}"/>
                            <igDP:SummaryDefinition SourceFieldName="SHORT_QTY"
                                                    Calculator="Sum"
                            <igDP:SummaryDefinition SourceFieldName="Net"
                                                    Calculator="Sum"
                            <igDP:SummaryDefinition SourceFieldName="LIVE_LONG_QTY"
                                                    Calculator="Sum"
                            <igDP:SummaryDefinition SourceFieldName="LIVE_SHORT_QTY"
                                                    Calculator="Sum"
                            <igDP:SummaryDefinition SourceFieldName="LiveNet"
                                                    Calculator="Sum"
                            <igDP:SummaryDefinition SourceFieldName="MUST_ROLL_LONG_QTY"
                                                    Calculator="Sum"
                            <igDP:SummaryDefinition SourceFieldName="MUST_ROLL_SHORT_QTY"
                                                    Calculator="Sum"
                            <igDP:SummaryDefinition SourceFieldName="MustRollNet"
                                                    Calculator="Sum"
                        </igDP:FieldLayout.SummaryDefinitions>
                    </igDP:FieldLayout>
                </igDP:XamDataGrid.FieldLayouts>
            </igDP:XamDataGrid>
        </Grid>
    </UserControl>
  • 8831
    posted in reply to Sam
    I'm not sure about the reason but if you post the working one I can look at it so we can find the difference. Also I've noticed that I have no email notification about  the last post I wrote at this thread yesterday and I guess you haven't such notification too. There I've put some code that has fixed ExpandDimensions() and some improvements about filtering as well.
    Regards.
    Plamen.
