980
XamGrid - have the same column layout for multiple grids
I have a window with multiple XamGrids but I am going to bind the same data structure to each of them. What is a good way to define the column layout once and then reference that layout with each of the grids? I would like to avoid maintaining multiple versions of the same column layout. For example, the following is from your samples:
<ig:XamGrid x:Name="dataGrid" AutoGenerateColumns="false" ItemsSource="{Binding Path=Customers}" ColumnWidth="*">
   <ig:XamGrid.Columns>
        <ig:TextColumn Key="CustomerID">
            <ig:TextColumn.HeaderTemplate>
                <DataTemplate>
                    <TextBlock Text="{Binding Path=XWG_Customers_CustomerID, Source={StaticResource Strings}}" />
                </DataTemplate>
            </ig:TextColumn.HeaderTemplate>
        </ig:TextColumn>
        <ig:TextColumn Key="Company">
                <DataTemplate>
                    <TextBlock Text="{Binding Path=XWG_Customers_Company, Source={StaticResource Strings}}" />
                </DataTemplate>
        </ig:TextColumn>
        <ig:TextColumn Key="ContactName">
                <DataTemplate>
                    <TextBlock Text="{Binding Path=XWG_Customers_ContactName, Source={StaticResource Strings}}" />
                </DataTemplate>
        </ig:TextColumn>
        <ig:TextColumn Key="ContactTitle">
                <DataTemplate>
                    <TextBlock Text="{Binding Path=XWG_Customers_ContactTitle, Source={StaticResource Strings}}" />
                </DataTemplate>
        </ig:TextColumn>
        <ig:TextColumn Key="Region">
                <DataTemplate>
                    <TextBlock Text="{Binding Path=XWG_Customers_Region, Source={StaticResource Strings}}" />
                </DataTemplate>
        </ig:TextColumn>
        <ig:TextColumn Key="Country">
                <DataTemplate>
                    <TextBlock Text="{Binding Path=XWG_Customers_Country, Source={StaticResource Strings}}" />
                </DataTemplate>
        </ig:TextColumn>
    </ig:XamGrid.Columns>
</ig:XamGrid>
Assuming I have this exact same layout for 5 different grids on the window, how would I allow each grid to share this layout?
Thanks!
