I've watched the sample eplaining how to put a separator in a XamMenu but that sample shows only how to separate vertical menus, If I made a toolbar horizontal menu, how can I group options as we use to do in Winforms ToolbarManager with the "Begin a Group" that put a vertical line in the toolbar and an horizontal line in the menu ?
Thank you in advance
Sabrina
That was it works perfectly
thank You
HI,
I am just following up.
Please let me know if you need further assistance.
Sincerely,
Mat Developer Support Engineer
HI Sabrina,
You can update the XamMenuSeparators Control Template
Here some code
<ig:XamMenu MenuOrientation="Horizontal" x:Name="xamMenu1" > <ig:XamMenuItem Header="File"> <ig:XamMenuItem Header="New" /> <ig:XamMenuItem Header="Open" /> <!-- Separator line--> <ig:XamMenuSeparator > </ig:XamMenuSeparator> <ig:XamMenuItem Header="Exit" /> </ig:XamMenuItem> <ig:XamMenuSeparator> <ig:XamMenuSeparator.Template> <ControlTemplate> <Rectangle Width="5" Fill="Black"/> </ControlTemplate> </ig:XamMenuSeparator.Template> </ig:XamMenuSeparator> <ig:XamMenuItem Header="Save"/> <ig:XamMenuItem Header="Run"/> </ig:XamMenu>
Sincerely, MattDeveloper Support Engineer
