Hi... i am using xamdatagrid and using "InfragisticsWPF4.DataPresenter.v11.2".Exception is raised as "Index was outside the bounds of the array." in the method VerifyCellsInView(Size elementSize).Exception decription is below. So plz check it and solve my problem
[General Info]
Application: 2012
Version: 1.1.153.3974
Region: English (India)
Machine: SHANKAR-PC
User: Shankar
Date: 15-06-2012
Time: 07:38
User Explanation:
Shankar said ""
[Exception Info 1]
Top-level Exception
Type: System.IndexOutOfRangeException
Message: Index was outside the bounds of the array.
Source: InfragisticsWPF4.DataPresenter.v11.2
Stack Trace: at Infragistics.Windows.DataPresenter.VirtualizingDataRecordCellPanel.VerifyCellsInView(Size elementSize)
at Infragistics.Windows.DataPresenter.VirtualizingDataRecordCellPanel.ArrangeOverride(Size finalSize)
at System.Windows.FrameworkElement.ArrangeCore(Rect finalRect)
at System.Windows.UIElement.Arrange(Rect finalRect)
at System.Windows.ContextLayoutManager.UpdateLayout()
at System.Windows.ContextLayoutManager.UpdateLayoutCallback(Object arg)
at System.Windows.Media.MediaContext.InvokeOnRenderCallback.DoWork()
at System.Windows.Media.MediaContext.FireInvokeOnRenderCallbacks()
at System.Windows.Media.MediaContext.RenderMessageHandlerCore(Object resizedCompositionTarget)
at System.Windows.Media.MediaContext.RenderMessageHandler(Object resizedCompositionTarget)
at System.Windows.Media.MediaContext.Resize(ICompositionTarget resizedCompositionTarget)
at System.Windows.Interop.HwndTarget.OnResize()
at System.Windows.Interop.HwndTarget.HandleMessage(WindowMessage msg, IntPtr wparam, IntPtr lparam)
at System.Windows.Interop.HwndSource.HwndTargetFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler)
[Assembly Info]
mscorlib, Version=4.0.0.0
System, Version=4.0.0.0
ExceptionReporter.WinForms, Version=2.1.1.0
mscorlib, Version=2.0.0.0
DocumanModel, Version=1.0.86.2800
Ionic.Zip, Version=1.9.1.8
MySql.Data, Version=6.4.3.0
System.Data, Version=4.0.0.0
System.Windows.Forms, Version=4.0.0.0
DotnetUtils, Version=1.0.0.0
PostSharp, Version=2.0.0.0
[Config Settings]
<?xml version="1.0"?>
<configuration>
<startup useLegacyV2RuntimeActivationPolicy="true">
<supportedRuntime version="v4.0" sku=".NETFramework,Version=v4.0"/>
</startup>
<system.diagnostics>
<sources>
<source name="mysql" switchName="SourceSwitch"
switchType="System.Diagnostics.SourceSwitch" >
</source>
</sources>
<switches>
<add name="SourceSwitch" value="Information" />
</switches>
</system.diagnostics>
</configuration>
[System Info]
Operating System
--CodeSet = 1252
--CSDVersion =
--CurrentTimeZone = 330
--FreePhysicalMemory = 867444
--OSArchitecture = 64-bit
--OSLanguage = 1033
--ServicePackMajorVersion = 0
--ServicePackMinorVersion = 0
--Version = 6.1.7600
Machine
-SHANKAR-PC
--Manufacturer = Gigabyte Technology Co., Ltd.
--Model = GA-MA78GM-US2H
--TotalPhysicalMemory = 3756515328
--UserName = Shankar-PC\Shankar
Hi.... The problem is solved and thanks for ur response......
Hello shankarnag,
We are still following this forum thread.Have you been able to verify if would be possible for you to provide us a small application that reproduces the mentioned behavior?
If you have any other questions or concerns about this matter please do not hesitate to contact us.
Hello Shankar,
Thank you for your post. I have been looking into it, but I cannot be completely sure how your data is organized and how it is connected to the DataPresenter I wasn’t able to reproduce your issue, so if this is still an issue for you, could you please send me an isolated sample project, where this is reproduced, so I can investigate it further for you.
