In XAML, how do I set the theme for a XamGrid. There doesn't seem to be a Theme property.
Thanks.
Hello Rakesh,
Here is the sample.
Hello Stefan,
Thanks for your reply,but I don't find the attached project. Can you please attach the same.
Rakesh
Thank you for your post. I have been looking into it and I created a sample project for you with the functionality you want. Also I can suggest you use our Color Tuner tool to set themes to Infragistics controls. Here you can find more information how to use this tool:
http://ko.infragistics.com/community/blogs/jordan_tsankov/archive/2012/05/01/how-to-use-the-infragistics-color-tuner-in-xaml-applications.aspx
and
http://help.infragistics.com/Help/NetAdvantage/WPF/2012.2/CLR4.0/html/Using_Infragistics_Color_Tuner.html
Please let me know if this helps you or you need further assistance on this matter.
Hi Duane,
Can you please provide a sample project for applying theme to xamgrid,
I did followed the link provided by you in one of above reply, but its not working for me and i am getting a lot of errors.
i did include these xaml's but it did not worked.
<ResourceDictionary Source="/TrainBraC_NG.Infrastructure;component/Themes/IG/IG.DataVisualization.xaml"/> <ResourceDictionary Source="/TrainBraC_NG.Infrastructure;component/Themes/IG/IG.xamMenu.xaml"/> <ResourceDictionary Source="/TrainBraC_NG.Infrastructure;component/Themes/IG/IG.xamGrid.xaml"/>
Hello elondon,
This is just a follow up if you require any further assistance.
