435
Wpf Data Template instance of user control
I have a XamTabControl with a few tabs. When tab is selected, I set the content of the tab to it's corresponding view model. Each view model is using the same user control, "BaseView"(which declared in a separate xaml and contains a XamDataGrid in it).
It's declared in the resources of the main xaml like this:
<DataTemplate x:Key="DocumentContentTemplate"  x:Shared="false">
      <v:BaseView DataContext="{Binding}" />
</DataTemplate>
And I use it in the XamTabControl in this way:
<igWindows:XamTabControl  Name="xamTabControl1" Grid.Row="1 "
ItemsSource="{Binding viewModels}" IsEnabled="True"
IsSynchronizedWithCurrentItem="True"
ContentTemplate="{StaticResource DocumentContentTemplate}">
Now my problem is that only one instance of the view is created for all the view model, although I used the attribute x:Shared="false" (as you can see in my example above).
Any suggestions?
  • 138253
    It has been a while since you have made your post, in case you still need support I will be glad to assist you further. I suppose the other community members can benefit from this answer as well. I have been looking into your post, but I cannot be completely sure how your data is organized how you created view model, so if this is still an issue for you, could you please send me an isolated sample project, where this is reproduced, so I can investigate it further for you.
