Hi ,
I have the below view
<igDP:XamDataGrid BindToSampleData="False" x:Name="dgUserAttributeList" GroupByAreaLocation="None"
DataSource="{Binding UserAttributes}"
BorderThickness="1" BorderBrush="{DynamicResource {x:Static SystemColors.ActiveBorderBrushKey}}"
ActiveDataItem="{Binding SelectedElement, Mode=OneWay, UpdateSourceTrigger=PropertyChanged}"
ScrollingMode="Immediate" Margin="0,5,0,0">
<igDP:XamDataGrid.FieldLayoutSettings>
<igDP:FieldLayoutSettings AllowAddNew="False" AllowDelete="False" AutoGenerateFields="False" />
</igDP:XamDataGrid.FieldLayoutSettings>
<igDP:XamDataGrid.FieldSettings>
<igDP:FieldSettings AllowEdit="False"
CellClickAction="SelectRecord"
AllowGroupBy="False" AllowHiding="Never"
AllowRecordFiltering="False" AllowSummaries="False" />
</igDP:XamDataGrid.FieldSettings>
<igDP:XamDataGrid.ViewSettings>
<igDP:GridViewSettings />
</igDP:XamDataGrid.ViewSettings>
<igDP:XamDataGrid.FieldLayouts>
<igDP:FieldLayout>
<igDP:Field Name="Name" Label="Name" Width="Auto" />
<igDP:Field Name="values" Label="DisplayValue" Width="*" />
</igDP:XamDataGrid.FieldLayouts>
</igDP:XamDataGrid>
i have a class type as
public class AttributeInfo{
public String Name { get { return this._Name; }
set
if (this._Name != value)
this._Name = value;
NotifyPropertyChanged("Name");
public String DisplayValue { get { return this._DisplayValue; }
if (_DisplayValue!=value)
_DisplayValue = value;
NotifyPropertyChanged("DisplayValue");
public List<string> values {
get {return this._values; }
set {
if (_values != value)
_values = value;
NotifyPropertyChanged("values");
In the view model i have created an observable collection property of type AttributeInfo(Above class).
public ObservableCollection<AttributeInfo> UserAttributes
get { return _UserAttributes; }
_UserAttributes = value;
RaisePropertyChanged("UserAttributes");
when i am trying to bind to xam grid only the names are showing but the values with a list is not showing up..
Please suggest.
It has been a while since you have made your post, in case you still need support I will be glad to assist you further. I suppose the other community members can benefit from this answer as well. I have been looking into your post and I can suggest you see this forum thread:
http://ko.infragistics.com/community/forums/p/34846/197255.aspx
where it is explained how to achieve the result you want.
