2940
Minimum and Maximum in Spin button issue.
Hi... I am using spin button control in my project.I am doing like this...
 <Editors:XamMaskedEditor  Grid.Column="4" Margin="5" Width="70" Mask="nnnn"
                IsAlwaysInEditMode="False" SpinIncrement="1" SpinWrap="True"
                                                     SpinButtonDisplayMode="Always" Theme="[Current]"                                DisplayMode="IncludeBoth"   Value="{Binding DocumentNumber, Mode=TwoWay, ValidatesOnDataErrors=True, UpdateSourceTrigger=PropertyChanged}"                                      DataMode="IncludeBoth" IsInEditMode="False" TrimFractionalZeros="False" />
How to add Minimum and maximum so that i want maximum value to set to 100 and minimum based on the user selection.I dont want to edit the editior only button should be work.If i add IsReadonly=True Spin buttons visibility is hidden.So how can i mke button visibile and user should not able to edit the text.
Please help to Solve this issue....
Parents
No Data
Reply
  • 138253
    It has been a while since you have made your post, in case you still need support I will be glad to assist you further. I suppose the other community members can benefit from this answer as well. I have been looking into your post and I believe I have already answered you here about using only the spin buttons for editing:
    http://ko.infragistics.com/community/forums/t/71064.aspx
    As for the Minimum and Maximum, I can suggest you use XamNumericEditor instead of XamMaskedEditor, since you will use it for numeric values, and add the following ValueConstraint in the Editor:
    <igEditors:XamNumericEditor.ValueConstraint>
        <igEditors:ValueConstraint MinInclusive="0" MaxInclusive="100"/>
    </igEditors:XamNumericEditor.ValueConstraint>
Children
No Data
