3627
Rightmost field is partially hidden under scrollbar
I just noticed this pehnomena and Removing the style of the grid doesn't seem to change the situation. My last field in the grid has a numeric value, which is half covered up by the scrollbar. If I disable AutoFit, The problem is "solved", but now the users are left to fend for themselves.
Even the field label isn't entirely visible - the right edge is hidden. It's as if the AutoFit logic fails to consider the width of the scrollbar.
Any ideas?
Thank you.
  • 138253
    Hello tbeaulieu,
    Thank you for your post. I have been looking through it and I suppose you have set the LabelMinWidth and this is why such behavior occurs  when the AutoFit property is set to True, so I suggest you either set the AutoFit property to False, as you said, or not set the LabelMinWidth. Please let me know if this helps you or I have misunderstood you and please note, we are making efforts to ensure all posts are addressed by an Infragistics expert. We believe that the other community members could benefit from this thread as well.
    Feel free to write me if you need further assistance.
