Hi
In my pivotgrid I have the following hierarchies :
On Columns - Geographies (e.g. World, Regions, Countries )On Rows - Items (e.g. Item Level 1, Item Level 2, Item Level 3)
and a single measure (Percentage Improvement) which has a custom aggregator which works out the weighted average improvement.
So the geographies hierarchy could contain:
World Europe UK Ireland France
and the items hierarchy:
Items Group 1 Items Group 2 Item 1 Item 2
I have implemented cell editing which is working but when I try to fine-tune it, I begin to get a little stuck so am hoping you'll be able to give me some direction.
1. In the example above, let's say that Item 1 can only have an improvement entered against the region level and so we need to disable direct user editing for UK, Ireland & France for Item 1. I have trapped the CellEnterEdit event but can't see anyway of cancelling the edit (or disallowing it). Is there a way?
2. Assuming the user has entered 10% against Europe for Item 1, I pass this value down to each of the child countries to keep the aggregator working but I don't want to display the value at country level for this item. Is this possible?
Keith
Currently the only ways to enter edit mode are by clicking the cell or hit "Enter". As for the multiple firing of the CellControlAttached event, you can use the Tag Property of the CellControl and check if you handled the PreviewLeftMouseButtonDown event for this cell or not. You can use the following code in the CellControlAttached event handler:
if (e.Cell.Control.Tag == null) { e.Cell.Control.Tag = "handled"; e.Cell.Control.PreviewMouseLeftButtonDown += Control_PreviewMouseLeftButtonDown; }
Please let me know if you have further questions on this matter.
Thanks you Stefan!
But you didn't answer on my another question: is there any other ways to enter edit mode besides mouse click and enter button? I need to restrict all ways to enter edit mode.
UPD. Stefan, in your attached example CellControl attached event fires multiple time for the same cell, which leads to multiple execution of PreviewLeftMouseButtonDown handler. This is a problem, what can I do about ut?
Instead of handling the PreviewMouseLeftButtonDown event, you can set the XamPivotGrid's EditSettings' AllowCellEdit Property to true and false based on the cell you click. Please let me know if this helps you or you need further assistance on this matter.
Stefan,
Unfortunately, I can't select any cells now. And worse, CellDoubleClicked is not firing now, and who knows what else can be wrong with this workaround.
How can I overcome this?
Thank you Stefan!
But edit can be triggered not only with clicking a cell, but with Enter button. I can add a PreviewKeyDown event for Enter key, but I need to know if there any other ways to edit cells to catch them all.
What are other ways to do this?
P.S. What is better: to ask questions on the forum or through the support cases?
