825
Binding a Custom Control, derived from a CellValuePresenter to the Settings.CellValuePresenterStyle of a Field failed
i'm trying to create some Editors as Custom Controls which i would use in a datagrid created in codebehind.
All works fine but i wanted to create a Custom Control which derives from the CellValuePresenter class.
The Template of my class is a Button.
The Control looks good but if i want to bind my Custom Control to the Settings.CellValuePresenterStyle of my field, an exception is thrown, which says my Custom Control is not a CellValuePresenter Class.
what can i do?
Here's the code of the Custom Control:
[TemplatePart(Name = "PART_DhpButton", Type = typeof(Button))]
    public class DhpButtonEditor : CellValuePresenter
        static DhpButtonEditor()
            DefaultStyleKeyProperty.OverrideMetadata(typeof(DhpButtonEditor),
                new FrameworkPropertyMetadata(typeof(DhpButtonEditor)));
        #region Events
        public override void OnApplyTemplate()
            base.OnApplyTemplate();
            Button dhpButton = base.GetTemplateChild("PART_DhpButton"as Button;
            if (dhpButton != null)
                dhpButton.Click += new RoutedEventHandler(DhpButton_Click);
        public delegate void Click_EventHandler(Object sender, RoutedEventArgs e);
        public event Click_EventHandler Click;
        private void DhpButton_Click(object sender, RoutedEventArgs e)
            if (this.Click != null)
                this.Click(sender, e);
        #endregion
here's the xaml code:
<Style
        x:Key="{x:Type local:DhpButtonEditor}"
        TargetType="{x:Type igDP:CellValuePresenter}"
        BasedOn="{StaticResource {x:Type igDP:CellValuePresenter}}">
        <Setter Property="Template">
            <Setter.Value>
                <ControlTemplate TargetType="{x:Type igDP:CellValuePresenter}">
                    <Button
                        Name="PART_DhpButton"
                        Margin="0,0,0,0"
                        Width="{TemplateBinding Width}"
                        Height="{TemplateBinding Height}"
                        Content="{TemplateBinding Content}" />
                </ControlTemplate>
            </Setter.Value>
        </Setter>
    </Style>
i try to bind the custom control like this:
Field field = new Field("Button");
field.Width = new FieldLength(50, FieldLengthUnitType.Auto);
Style buttonStyle = new Style(typeof(DhpButtonEditor));
field.Settings.CellValuePresenterStyle = buttonStyle;
fieldLayout.Fields.Add(field);
i attached an examle!
THanks for the help.
Jochen
DhpControls.zip
