I am adding a new record to my xamdatagrid. But during the record initialization I want to access the last cell and make the button control invisible. Can someone please suggest when and how can I access or change the style of newly added record before it is visible to the user.
Megha
Hello Megha,
Thank you for your post. I have been looking into it and I suggest you create a Style for the CellValuePresenter and handle its Loaded event like this:
<Style TargetType="igDP:CellValuePresenter"> <EventSetter Event="Loaded" Handler="cvpLoaded"/> </Style>
And add the following handler:
private void cvpLoaded(object sender, RoutedEventArgs e) { if ((sender as CellValuePresenter).Field.Index == (sender as CellValuePresenter).Field.Owner.Fields.Count-1) { //Here you can get the CellValuePresenter and modify it (sender as CellValuePresenter).Background = Brushes.Red; } }
Please let me know if this helps you or you need further assistance on this matter.
