770
xamOrgChart. Detecting click on background
I want to deselect the selected node in xamOrgChart when user clicks outside a node, that is, when user clicks the background. I have panning and zooming on. How can I detect user clicks on background in order to deselect the selected node?
  • 28407
    Verified Answer
     HI Isidoro,
     Wire up charts PreviewMouseLeftButtonDown event and check to see if you moused down on an OrgChartNodeControl.
     If you didnt mouse down on this control, then clear the charts selection.
     Here a code snippet:
    private void chart_PreviewMouseLeftButtonDown(object sender, MouseButtonEventArgs e)         {             DependencyObject source = e.OriginalSource as DependencyObject;
                if (source == null) return;
                OrgChartNodeControl cvp = Infragistics.Windows.Utilities.GetAncestorFromType(source, typeof(OrgChartNodeControl), true) as OrgChartNodeControl;
                if (cvp == null)             {                 chart.SelectedNodes.Clear();             }
     Sincerely,
     Matt
     Developer Support Engineer
