945
empty chart but the object appears to be populated
Have the following XAML code for a ToolWindow, the window appears but the chart is blank...Using the debugger to examine the xamDataChart object all Itemsources and setting are correct. Can't understand what is out of alignment.
<Window x:Class="PaddockGRASP.Views.GraphWindow"
xmlns:ig="http://schemas.infragistics.com/xaml"
xmlns:System="clr-namespace:System;assembly=mscorlib"
Title="Results Graph Window" Height="300" Width="600"
ShowInTaskbar="False" WindowStyle="ToolWindow"
DataContext="{Binding Main, Source={StaticResource Locator}}">
<Window.Resources>
<ig:StringFormatConverter x:Key="StringFormatConverter" />
<DataTemplate DataType="{x:Type System:DateTime}">
<TextBlock Text="{Binding StringFormat={}{0:MMM yyyy}}"/>
</DataTemplate>
<SolidColorBrush x:Key="StripBrush" Color="#7FC1C1C1" />
<SolidColorBrush x:Key="StrokeBrush" Color="LightGray" />
<Style x:Key="CategoryXAxisElementStyle" TargetType="ig:CategoryDateTimeXAxis">
<Setter Property="Interval" Value="12" />
<Setter Property="StrokeThickness" Value="1" />
<Setter Property="Strip" Value="{StaticResource StripBrush}" />
<Setter Property="Stroke" Value="{StaticResource StrokeBrush}" />
<Setter Property="StrokeThickness" Value="12" />
<Setter Property="MajorStroke" Value="{StaticResource StrokeBrush}" />
<Setter Property="MajorStrokeThickness" Value="0.5" />
<Setter Property="MinorStroke" Value="{StaticResource StrokeBrush}" />
<Setter Property="MinorStrokeThickness" Value="0.075" />
</Style>
<Style x:Key="NumericYAxisElementStyle" TargetType="ig:NumericYAxis">
<Setter Property="Strip" Value="Transparent" />
<Setter Property="StrokeThickness" Value="2.5" />
<Setter Property="MinorStrokeThickness" Value="0.125" />
</Style>
<Style x:Key="CrosshairStyle" TargetType="Line">
<Setter Property="Stroke" Value="Black" />
<Setter Property="Opacity" Value="0.7" />
<Setter Property="StrokeThickness" Value="2.0" />
</Style>
</Window.Resources>
<Grid>
<ig:XamDataChart x:Name="xamDataChart"
HorizontalZoomable="True"
HorizontalZoombarVisibility="Visible"
CrosshairLineStyle="{StaticResource CrosshairStyle}"
CrosshairVisibility="Visible" Margin="2,0,2,2" Padding="0" MouseRightButtonDown="xamDataChart_MouseRightButtonDown">
<ig:XamDataChart.Axes>
<ig:CategoryDateTimeXAxis x:Name="xmXAxis"
ItemsSource="{Binding Path=Project.ActiveScenario.ActiveResults}"
DateTimeMemberPath="Date"
Label="{}{Date:MMM yyyy}"
Style="{StaticResource CategoryXAxisElementStyle}">
<ig:CategoryDateTimeXAxis.LabelSettings>
<ig:AxisLabelSettings FontFamily="Segoe UI" FontSize="10" Foreground="Black" FontWeight="Bold" />
</ig:CategoryDateTimeXAxis.LabelSettings>
</ig:CategoryDateTimeXAxis>
<ig:NumericYAxis x:Name="xmYAxis"
Style="{StaticResource NumericYAxisElementStyle}">
<ig:NumericYAxis.LabelSettings>
Location="OutsideLeft" />
</ig:NumericYAxis.LabelSettings>
</ig:NumericYAxis>
<ig:NumericYAxis x:Name="xmYAxis2">
Location="OutsideRight" />
</ig:NumericYAxis>
</ig:XamDataChart.Axes>
<ig:XamDataChart.Series>
<ig:LineSeries ItemsSource="{Binding Path=Project.ActiveScenario.ActiveResults}" XAxis="{Binding ElementName=xmXAxis}" YAxis="{Binding ElementName=xmYAxis}" ValueMemberPath="Rain" MarkerType="None" Title="Monthly Rainfall"
TrendLineType="SimpleAverage"
TrendLineBrush="LightCoral"
TrendLinePeriod="{Binding ElementName=sldTrendLinePeriod, Path=Value, Converter={StaticResource StringFormatConverter}, ConverterParameter='0'}"
TrendLineThickness="2"/>
<ig:LineSeries ItemsSource="{Binding Path=Project.ActiveScenario.ActiveResults}" XAxis="{Binding ElementName=xmXAxis}" YAxis="{Binding ElementName=xmYAxis}" ValueMemberPath="TSDM" MarkerType="None" Title="TSDM"/>
<ig:LineSeries ItemsSource="{Binding Path=Project.ActiveScenario.ActiveResults}" XAxis="{Binding ElementName=xmXAxis}" YAxis="{Binding ElementName=xmYAxis}" ValueMemberPath="Growth" MarkerType="None" Title="Growth" />
<ig:LineSeries ItemsSource="{Binding Path=Project.ActiveScenario.ActiveResults}" XAxis="{Binding ElementName=xmXAxis}" YAxis="{Binding ElementName=xmYAxis2}" ValueMemberPath="LWG" MarkerType="None" Title="Live Weight Gain" />
<ig:LineSeries ItemsSource="{Binding Path=Project.ActiveScenario.ActiveResults}" XAxis="{Binding ElementName=xmXAxis}" YAxis="{Binding ElementName=xmYAxis2}" ValueMemberPath="SoilLoss" MarkerType="None" Title="Soil Loss" />
<ig:LineSeries ItemsSource="{Binding Path=Project.ActiveScenario.ActiveResults}" XAxis="{Binding ElementName=xmXAxis}" YAxis="{Binding ElementName=xmYAxis2}" ValueMemberPath="RadCover" MarkerType="None" Title="Radiation Cover" />
</ig:XamDataChart.Series>
</ig:XamDataChart>
<StackPanel Orientation="Vertical" Margin="229,0,183,226" HorizontalAlignment="Center" Width="166">
<TextBlock Text="TrendLine Period" Margin="2" HorizontalAlignment="Center" FontSize="10" FontWeight="Bold" />
<StackPanel Orientation="Horizontal" HorizontalAlignment="Center">
<Slider x:Name="sldTrendLinePeriod" Width="120" Value="12" Minimum="1" Maximum="24" TickFrequency="24" TickPlacement="BottomRight" HorizontalAlignment="Left" Height="16" SmallChange="1" SnapsToDevicePixels="False" />
<TextBlock Width="30" Text="{Binding Value, ConverterParameter=0, Converter={StaticResource StringFormatConverter}, ElementName=sldTrendLinePeriod}" TextAlignment="Center" HorizontalAlignment="Right" />
</StackPanel>
</StackPanel>
</Grid>
Window>
the binding is to
public
ObservableCollection<GRASPRecord> ActiveResults
get { return _activeResults; }
and
Serializable]
IgnoreFirst(1)]
FixedLengthRecord()]
public class GRASPRecord
FieldFixedLength(8)]
FieldConverter(ConverterKind.Date, "yyyyMMdd")]
public DateTime Date;
public float Rain;
public float TSDM;
public float Growth;
public float Cover;
public float Runoff;
public float SoilLoss;
public float LWG;
public float Beasts;
public float Eaten;
public float RadCover;
