825
HeaderPrefixArea MouseLeftButtonDown Event with a xamDataGrid in code behind
i'm trying to implement a MouseLeftButtonDown Event in the HeaderPrefixArea in a code behind xamDataGrid,
but i can't get it work!
Everything works fine if i build a xamDataGrid in XAML and modify the HeaderPrefixAreaStyle in the Resources of the xamDataGrid in XAML.
But if i try to do similar things in an code behind grid, i fail everytime.
I used this article as reference: http://ko.infragistics.com/community/forums/p/67080/339815.aspx#339815
I attached an example project which explains all.
Thanks for your help,
Jochen
xamDataGrid_HeaderPrefixArea.zip
  • 12875
    Verified Answer
    Hi Jochen,
    I modified your sample's InitHeaderPrefixArea function adding a ControlTemplate and a textBlock to which I added an event handler.
    Here's the section of code that I changed:
    public void InitHeaderPrefixArea()
                Style headerPrefixAreaStyle;
                ControlTemplate ct = new ControlTemplate(typeof(Infragistics.Windows.DataPresenter.HeaderPrefixArea));
                TextBlock txtblock = new TextBlock();
                txtblock.PreviewMouseLeftButtonDown += new MouseButtonEventHandler(txtblock_PreviewMouseLeftButtonDown);
                FrameworkElementFactory txtblock1 = new FrameworkElementFactory(typeof(TextBlock));
                txtblock1.AddHandler(UIElement.PreviewMouseLeftButtonDownEvent, new MouseButtonEventHandler(txtblock_PreviewMouseLeftButtonDown));
                ct.VisualTree = txtblock1;
                if (example == Example.Example1)
                    // TEST 1 - failed
                    headerPrefixAreaStyle = new Style(typeof(Infragistics.Windows.DataPresenter.HeaderPrefixArea));
                    headerPrefixAreaStyle.Setters.Add(new Setter(Infragistics.Windows.DataPresenter.HeaderPrefixArea.HorizontalAlignmentProperty, HorizontalAlignment.Center));
                    headerPrefixAreaStyle.Setters.Add(new Setter(Infragistics.Windows.DataPresenter.HeaderPrefixArea.VerticalAlignmentProperty, VerticalAlignment.Center));
                    headerPrefixAreaStyle.Setters.Add(new Setter(Infragistics.Windows.DataPresenter.HeaderPrefixArea.VisibilityProperty, Visibility.Visible));
                    //headerPrefixAreaStyle.Setters.Add(new EventSetter(Infragistics.Windows.DataPresenter.HeaderPrefixArea.PreviewMouseLeftButtonDownEvent, new System.Windows.Input.MouseButtonEventHandler(HeaderPrefixArea_MouseButtonDown)));
                    headerPrefixAreaStyle.Setters.Add(new Setter( TemplateProperty, ct));
                Else
    When I added the event it generated the following block of code to which I added the message box.
    void txtblock_PreviewMouseLeftButtonDown(object sender, MouseButtonEventArgs e)
         MessageBox.Show(" textblock clicked");
    This event fires when I click on the header prefix area of the Example1 layout.
