Our ui requires that we construct complex objects that contain a collection of "sub-objects" and bind them to a XamDataGrid in code via UnboundField objects. A property of the sub-object is then displayed in the ui (Factor in this case). This works perfectly with changes in the ui correctly being made to the underlying sub-object. This sub-object contains an Error property which contains the result of any edit rules validation. When I try to bind the Error property to the UnboundField ToolTip property in a way similar to how the Factor property was bound it always fails. Below is the code that builds the columns for the ui:
foreach (BusinessRevisionFactorColumn brfCol in columns)
UnboundField uf = new UnboundField(); //string.Format("Hrs[{0}]", i));
uf.BindingPath = new PropertyPath(string.Format("FactorsArray[{0}].Factor.Factor", i));
uf.BindingMode =BindingMode.TwoWay;
uf.Label = brfCol.Name;
Binding ttBinding = new Binding()
Path =new PropertyPath(string.Format("FactorsArray[{0}].Factor.Error", i)),
RelativeSource =new RelativeSource(RelativeSourceMode.Self)
BindingOperations.SetBinding(uf, UnboundField.ToolTipProperty, ttBinding);
uf.DataType =typeof(double);
uf.Settings.LabelTextWrapping =TextWrapping.Wrap;
uf.Settings.CellValuePresenterStyle = (Style)idgvFactors.FindResource("FactorCellsStyle");
uf.Settings.AllowResize =false;
fl.Fields.Add(uf);
i++;
I need to get access to the Error property in the MouseEnter event of the CellValuePresenter but can't find a way to get to the correct sub-object via the DataContext DataItem since these sub-objects live in a collection/array within the DataItem. I don't need to use the ToolTip if there's a way to get to the correct sub-object via some other mechanism.
Can you point me in a direction to pursue?
Thanks!
Glenn
Hello Glenn,
Thanks again.
Hi Stefan,
Worked perfectly!
Thanks for the help and the amazingly quick response.
I have been looking into your sample and I modified it so now it has the functionality you want.
Hope this helps you.
Hi Stefran,
I've finally had some time to create a sample program for you.
I've set a break point in Control_MouseEnter that you'll hit when you mouse over any of the cells containing an amount. That is the point that I need to access the actual underlying object for that specific cell in order to get to its "Error" property. How do I get to that object?
I am looking forward for your reply.
