700
xamDataGrid row combobox changed event?
hi,
I am trying to filter the contents of a dropdown, based on another dropdown in the same row.
I can do filtering using a ValueConverter , however, i don't know how to get a reference to the value of the other field (also a dropdown).
Here is my grid field definition (this is the column that has a dropdown that should be filtered based on another columns selected value):
    <igDP:Field Label="Category" Width="100">
        <igDP:Field.Settings>
            <igDP:FieldSettings EditorType="{x:Type igEditors:XamComboEditor}" AllowEdit="True">
                <igDP:FieldSettings.EditorStyle>
                    <Style TargetType="{x:Type igEditors:XamComboEditor}">
                        <Setter Property="ItemsSource" Value="{Binding Path=DataContext,
                            RelativeSource={RelativeSource Mode=FindAncestor,AncestorType={x:Type v:AdjustmentsView_EditGrid}},
                            Converter={StaticResource CategoryConverter}}" />
                        <Setter Property="DisplayMemberPath" Value="Name" />
                        <Setter Property="ValuePath" Value="Name" />
                    </Style>
                </igDP:FieldSettings.EditorStyle>
            </igDP:FieldSettings>
        </igDP:Field.Settings>
    </igDP:Field>
The only way i thought of doing this, was if i could somehow update record on every selection of the other dropdown. If i can update record immediately after changing a selection, my converter would know how to filter the list.
