The Goal is to color the cell CDvi_CodDvi : red if CDvi_CodCli = 0 and blue if not .
The following Xaml dot work ( i work with thee sample of infragistic )
The converter : passingToColorConverter is good.
Where is the error
thank you Caiseodev
<igDP:XamDataPresenter Name="XDPDevis" SelectedItemsChanged="XDPDevis_SelectedItemsChanged" RecordActivated="XDPDevis_RecordActivated">
<igDP:XamDataPresenter.FieldSettings>
<igDP:FieldSettings AllowEdit="False" />
</igDP:XamDataPresenter.FieldSettings>
<igDP:XamDataPresenter.FieldLayoutSettings>
<igDP:FieldLayoutSettings AutoGenerateFields="False"/>
</igDP:XamDataPresenter.FieldLayoutSettings>
<igDP:XamDataPresenter.FieldLayouts >
<igDP:FieldLayout >
<igDP:FieldLayout.Fields>
<igDP:Field Name="CDvi_CodDvi" Label="Code" Width="70" >
<igDP:Field.Settings>
<igDP:FieldSettings CellWidth="70" LabelWidth="70">
<igDP:FieldSettings.CellValuePresenterStyle>
<Style TargetType="{x:Type igDP:CellValuePresenter}">
<Setter Property="Background"
Value="{Binding Path=Cells[CDvi_CodCli].Value, Converter={StaticResource passingToColorConverter}}">
</Setter>
</Style>
</igDP:FieldSettings.CellValuePresenterStyle>
</igDP:FieldSettings>
</igDP:Field.Settings>
</igDP:Field>
<igDP:Field Name="CDvi_CodCli" Label=" Client" Width="30"></igDP:Field>
<igDP:Field Name="NomCli" Label=" Client" Width="120"></igDP:Field>
<igDP:Field Name="CDvi_DatDvi" Label="Date" Width="70"></igDP:Field>
<igDP:Field Name="CDvi_DesDvi" Label="Designation" Width="150"></igDP:Field>
</igDP:FieldLayout.Fields>
</igDP:FieldLayout>
</igDP:XamDataPresenter.FieldLayouts>
</igDP:XamDataPresenter>
Ok , It's Work Fine.
I made a lot of progress to DataPresenter with you.
Thank You Caisseodev
According to your last post I understand that you would like to change the Background of filed’s cells according to the value of the cells of another field in the XamDataGrid. I have modified my sample application(DynamicStylingModified.zip) in order to meet exactly this scenario.
If I have misunderstood you in any way, feel free to ask.
I Have read the link of ‘RelativeSource Self’.
But my problem is to color a cell with test of a other cell.
In your sample : color the cell : 'firstName' and test cell 'probation.
Excuse me for my explanations
thank you CaisseOdeV
Thank you for your feedback. I have used ‘RelativeSource Self’ in order to bind the ‘Background’ property to itself and manipulate it through converter. For more information regarding RelativeSource, please look through the following MSDN link :
http://msdn.microsoft.com/en-us/library/dd553635(v=vs.95).aspx
If you need any further assistance on this matter, feel free to ask.
Thank you so much. It's Work fine.
Just other question :
<Setter Property="Background" Value="{Binding Path=Value, RelativeSource={RelativeSource Self}, Converter={StaticResource doubleToColorConverter}}"/>
In this line : what means : RelativeSource={RelativeSource Self},
CaiseOdev
