HI,
how do i access the header of xampresenter (datacard option)?
my code looks like:
Private Sub myDataPresenter_RecordActivated(sender As Object, e As Infragistics.Windows.DataPresenter.Events.RecordActivatedEventArgs) Handles myDataPresenter.RecordActivated
If TypeOf e.Record Is FilterRecord Then Exit Sub End If
' Check to make sure the selected Record is a DataRecord If TypeOf e.Record Is DataRecord Then ' Cast the record passed in as a DataRecord Dim myRecord As DataRecord = CType(e.Record, DataRecord)
'bring up the extra required fields Dim myProgrammeExerciseSpecs As New ProgrammeExerciseSpecs
myProgrammeExerciseSpecs.exerciseid =THIS IS WHERE I NEED TO GET THE HEADER TEXT myProgrammeExerciseSpecs.programmid = myprogrammeid myProgrammeExerciseSpecs.programmetitle = Me.cbotitle.Text.ToString() myProgrammeExerciseSpecs.programmedesc = Me.txtcontent.Text.ToString() myProgrammeExerciseSpecs.lbltitle.Content = myRecord.Cells(0).Value.ToString() myProgrammeExerciseSpecs.txtcontent.Text = myRecord.Cells(1).Value.ToString() myProgrammeExerciseSpecs.ShowDialog()
End If
End Sub
I have attached a VB version of the sample. Please let me know if this helps you or you need further assistance on this matter.
when i try and use the line below which you used in your example vb.net does not recognise it. if i do .name.tostring or .label.tostring it just returns the content of the label, and not the field value.
.....FieldLayout.PrimaryField.Name.value.tostring
I have created a sample project for you with the functionality you want. Basically I didn’t set the Header Path, but I set the IsPrimaryField Property of the Field I want to show as header to True. And then by getting the primary field I was able to get the header value. Please let me know if this helps you or you need further assistance on this matter.
Hi Stefan,
does not seem to do what i am after.
my xaml looks like below. the field i need to get to via vb is the HeaderPath:
<igDP:XamDataPresenter.View> <igDP:CardView> <igDP:CardView.ViewSettings> <igDP:CardViewSettings HeaderPath="ExerciseID" CollapseCardButtonVisibility="Hidden" ShouldAnimateCardPositioning="False" /> </igDP:CardView.ViewSettings> </igDP:CardView> </igDP:XamDataPresenter.View>
Thank you for your post. I have been looking into it and I can suggest you use the following code to get the ActiveRecord’s Header Text:
e.Record.FieldLayout.PrimaryField.Label.ToString
