975
Click into column filter dropdown area is routed to combobox inside cellvaluepresenter
i have set a cell value presenter to show a normal wpf-combo box right inside the grid. Now if i open the column filter combobox and click an item inside the drop down area of the column filter it will not select the filtered value.
Instead the combo box inside the cell area will be opened that is just behind the filter value i was intended to select. It behaves just as if the dropdown area of the filter area was not there.
