I posted yesterday about using the XamFormulaEditor in the XamDataGrid. That post was answered and allowed me to keep investigating the XamFormulaEditor. I've now seen how to add named references and custom functions to the formula editor dialog and that goes a long way to finishing up.
Now I need to know how to remove the control list from the dialog. Basically, it appears that the dialog is displaying the formula target control ("FormulaTarget" in the attached example) for each row in my grid. I'm not using the target control, and in fact it's not even visible on the form, so I'd like to just remove the control list entirely from the dialog. Is there any way to do that?
Alternatively, it appears that I can filter the Operands to the Named References that I've added. If I can't remove the control list, is there a way I can programatically apply the Operands filter and then prevent the user from changing it?
I've attached the updated project from yesterday to illustrate the issue.
Steve
Hello Ananthan,
It has been a while since you have made your post, in case you still need support I will be glad to assist you further. I suppose the other community members can benefit from this answer as well. I have been looking into it and I can suggest you see the sample from this forum thread:
http://ko.infragistics.com/community/forums/t/65646.aspx
which has the functionality you want.
Hi Stefan.
We are having an issue integrating the XamFormulaEditor control with XamDataGrid control for calcuation.
I am trying to integrate the formula editing feature with my XamDataGrid control in our WPF application. The control has its AutoGenerateFields property set to false and it binds data successfully. I have a XamFormulaEditor control on the Window to allow the user build his own formula and add the result as a new field(column) into the existing XamDataGrid.I have set the Target property of the XamFormulaEditor as
Target="{Binding ElementName=xamGrid}".
I can enter the formula like "[Last4] + 2" and have my new column with correct value. The problem is that when I use the built in ContextualHelp feature by using the autocomplete suggestions and the operands list, the result goes wrong as the source column is always of Row at 0, because the formula becomes like
"[Last4] + 2"
[//dataPresenterAdapter/Table(0)/counsel_Status_Id]
Basically we need to have a FormulaEditor control that can be used to create a new Field in the XamDataGrid using CalculationManager.Do any of you have an idea that might be useful in this context?Or do you have a sample that implements the same logic?
Hello Steve,
Thanks again.
Thanks, Stefan. I've reviewed the project you attached and I think it does exactly what I need. Thanks again for the prompt reply.
