I try to move my first column of xamdatagrid to last(having 300 columns) and it's quite slow with xamdatagrid version 11. When i try the same with xamdatagrid version 10.3 it works fine and quite fast.
Steps: Select the header of first column with mouse and drag quickly to last( mouse should go out of focus from the grid) then columns scrolling is very slow
Constraint : I can not upgrade/degrade my infragistics xam data grid version.
So if there is any work around so that i can improve column moving faster.
Hello Kimberly,
Thank you for your post. I have created a case with number CAS-107653-M2V7P5 in order to attach your sample application and video as zip files. Let’s continue our discussion in the case.
Hello, I've created a small POC that shows you the problem and a video that demonstrates the issues we having with scroll lagging and grid being very slow. It seems to be more of an issue when we have AutoFit=true. I am having some problems attaching it to this forum. Can you send me an email address I can send you the files in a zip.
I have been trying to reproduce your issue using the latest Service Release without success. If possible please attach a sample application that reproduce it in order to investigate it.
Also note that after we have tried to use horizontal scroll the whole grid performance goes down hill. We really need some help with this. I've tried everythign you suggested in this post http://ko.infragistics.com/community/blogs/kiril_matev/archive/2010/10/26/optimizing-xamdatagrid-performance.aspx and nothing seems to help. I'm currently working on putting together some POC's and going to submit a case if we don't get any resolution on performance issues witht he xamdatagrid.
Hi I installed the latest service release 2288 of 11.2 and still seeing very slow horizontal scroll performance. Any suggestions?
