435
StackedBarSeries and tooltip
Hi
I create my XamDataChart with one NumericXAxis and CategoryYAxis.
I create StackedBarSeries with GroupBy item source with AutoGenerateSeries = true.
Detail description here http://ko.infragistics.com/community/forums/t/73787.aspx
I need now create toolTip for my series and segment. How i do it?
Binding like
<DataTemplate x:Key="ToolTipTemplate">
<StackPanel>
<TextBlock Text="{Binding Item.Key}" />
<TextBlock Text="{Binding Item.Hodnota}" />
</StackPanel>
</DataTemplate>
 not working.
  • 435
    Verified Answer
    Hi
    I found solution thrue convertor.
    I create datatemplate for ToolTip
    <local:SeriesConverter x:Key="seriesConverter" />
    <StackPanel>
    <StackPanel Orientation="Horizontal">
    <TextBlock Text="Název: " FontWeight="Bold"/>
    <TextBlock Text="{Binding Path=., Converter={StaticResource seriesConverter}, ConverterParameter=FragmentNazev}" />
    </StackPanel>
    <TextBlock Text="Období: " FontWeight="Bold"/>
    <TextBlock Text="{Binding Path=., Converter={StaticResource seriesConverter}, ConverterParameter=Datum}" />
    </StackPanel>
    <TextBlock Text="Hodnota: " FontWeight="Bold" />
    <TextBlock Text="{Binding Path=., Converter={StaticResource seriesConverter}, ConverterParameter=Hodnota, StringFormat=F2}" />
    </StackPanel>
    </StackPanel>
    </DataTemplate>
    in code a write:
    StackedBarSeries series2 = new StackedBarSeries();
    //udalost kde pregeneruju titulek ktery se generuje blbe
    series2.SeriesCreated += series2_SeriesCreated;
    series2.Legend = this.xmLegend;
    series2.XAxis = xAxis;
    series2.YAxis = yAxis;
    series2.AutoGenerateSeries = true;
    //tooltip
    var toolTipTemplate = this.DataChart.Resources["ToolTipTemplate"] as DataTemplate;
    if (toolTipTemplate != null)
    var toolTip = new ContentControl();
    toolTip.ContentTemplate = toolTipTemplate;
    Binding b2 = new Binding(".");
    toolTip.SetBinding(ContentControl.ContentProperty, b2);
    series2.ToolTip = toolTip;
    series2.ItemsSource = gb;
    this.DataChart.Series.Add(series2);
    And code for convertor is:
    public class SeriesConverter : IValueConverter
    public object Convert(object value, Type targetType, object parameter, System.Globalization.CultureInfo culture)
    Infragistics.Controls.Charts.DataContext dc = value as Infragistics.Controls.Charts.DataContext;
    if (dc != null)
    Infragistics.Controls.Charts.AnchoredCategorySeries cs = dc.Series as Infragistics.Controls.Charts.AnchoredCategorySeries;
    string klic = cs.ValueMemberPath.Replace("_Hodnota", string.Empty);
    klic = klic + "_" + parameter.ToString();
    Binding b = new Binding();
    b.Path = new PropertyPath(klic);
    b.Source = dc.Item;
    FrameworkElement fe = new FrameworkElement();
    fe.SetBinding(FrameworkElement.TagProperty, b);
    fe.DataContext = dc.Item;
    return fe.Tag;
    else
    return null;
    public object ConvertBack(object value, Type targetType, object parameter, System.Globalization.CultureInfo culture)
    return null;
