I like to use the Tile Manager without the headers, with this Forum help i found out how. But now the question,how can I miximize a current Tile via Code. I can only found a reference of a tile if I have a Item, but when i click of a button inside the Tile i found now "actualTile" or "currentNode" or whatever.
For example: this work for the fix first Item, but I search the current...
private void _tm_MouseDoubleClick(object sender, MouseButtonEventArgs e) { XamTile tileToMaximize = this._tm.TileFromItem(this._tm.Items[0]); tileToMaximize.IsMaximized = true;
Thanks for help, and greetings from germany
Thomas
Hello Thomas,
I can suggest you set the ContentTemplate Property of the ContentPresenter, which is in the XamTile's Template, to {TemplateBinding ContentTemplateResolved}. This way the ItemTempalteMaximized and ItemTemplateMinimizedExpanded Properies will work correctly.
Hope this helps you.
Hello Stefan,
your solution doesn't work. Only the content will maximized. But it is the wrong content. The content should change to TemplateMaximized.The button should be replaced with a Text "MytextBlock Maximized"
Thx for help
I have been looking into your code and I can suggest you replace the StackPanel used in the XamTile's Style Tempalte with Grid.
based on the previous problem a new problem is added.In the sample Code I remove the header and build templates for the maximzed and minimizedExpanded view.if I used the tilemanager with normal header everythinbgs works fine, but when i remove the header then the view will maximized but there content is always the same, it doesn't change to the template. Where is the Problem ? I think the style for xamTile WithoutHeader remove the contents or fixed it to the normal view.
<Window x:Class="WpfApplication1.MainWindow" xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation" xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml" xmlns:igPrim="http://schemas.infragistics.com/xaml/primitives" Title="MainWindow" Height="350" Width="525" xmlns:ig="http://schemas.infragistics.com/xaml"> <Window.Resources> <!-- TILE MANAGER--> <!-- style for TileHeaderPresenter will use in the style for xamTile (found in infragistic forum)--> <Style x:Key="tileHeaderStyle" TargetType="igPrim:TileHeaderPresenter"> <Setter Property="Template"> <Setter.Value> <ControlTemplate TargetType="igPrim:TileHeaderPresenter"> <Grid Background="Transparent"> <ContentPresenter /> </Grid> </ControlTemplate> </Setter.Value> </Setter> </Style> <!-- style for xamTile that will apply on all tiles (found in infragistic forum)--> <Style TargetType="ig:XamTile" x:Key="WithoutHeader"> <Setter Property="Template"> <Setter.Value> <ControlTemplate TargetType="ig:XamTile"> <StackPanel> <igPrim:TileHeaderPresenter x:Name="TileHeader" AutomationProperties.AutomationId="TileHeader" Style="{StaticResource tileHeaderStyle}"> <ContentPresenter Visibility="{TemplateBinding ContentVisibility}"/> </igPrim:TileHeaderPresenter> <Rectangle x:Name="Overlay"/> </StackPanel> </ControlTemplate> </Setter.Value> </Setter> </Style> <DataTemplate x:Key="TemplateMaximized"> <Grid> <TextBlock>MytextBlock Maximized</TextBlock> </Grid> </DataTemplate> <DataTemplate x:Key="TemplateMinimized"> <Grid> <TextBlock>MytextBlock Minimized</TextBlock> </Grid> </DataTemplate> <DataTemplate x:Key="LargeTileView"> <Button Name="myTestButton" Content="{Binding Source}" Click="Button_Click"/> </DataTemplate> </Window.Resources> <Grid> <ig:XamTileManager Name="xamTileManager1" ItemTemplate="{StaticResource LargeTileView}" ItemsSource="{x:Static Fonts.SystemFontFamilies}" ItemTemplateMaximized ="{StaticResource TemplateMaximized}" ItemTemplateMinimizedExpanded="{StaticResource TemplateMinimized}" ItemContainerStyle="{StaticResource WithoutHeader}" > <!-- Remove the last line with the ItemContainerStyle for the normal view with header--> </ig:XamTileManager> </Grid></Window>
--Code Behind private void Button_Click(object sender, RoutedEventArgs e) { ((((sender as Button).TemplatedParent) as ContentPresenter).TemplatedParent as XamTile).IsMaximized = true; }
By the way, is it possible to change the itemcontainerstyle from one view to another? I think no, without reload the items the tiles can't change the header view.I'd prefer the first view without the header and after maximized the view with header. Any idea.
greetings
Thanks again.
