660
ArgumentNullException was unhandled "Key cannot be null". XamDataGrid binding.
What I have is a project that takes an xml definition and draws screens from code behind only. This is the way that this project has to be done. The project is using Full .NET 4.0 (no client profile), Entity Framework 5.0 and Infragistics WOF LOB 12.1 . Note that ParentData is an instance of the Entities, and WorkArea is a globally used Dictionary(of String, DBSet). I receive the error "ArgumentNullException was unhandled" along with the "Key cannot be null" error when the data is binding if I remove the pointer to set the grid's datasource the issue does not occur. From the names of the methods in the stack below it appears that the grid is trying to autofit itself. As you can see I am setting the row and column for the field to position them in very specific locations and hacking the use of the ColumnSpan to actually position the columns based on the widths of the fields. However, I removed all of this code and still get the same error. Can anyone shed some light on this?
Thank You
Devin
        Dim xdg As New XamDataGrid
        Dim flc As FieldLayoutCollection = xdg.FieldLayouts
        xdg.AutoFit = True
        xdg.FieldLayoutSettings.AutoFitMode = AutoFitMode.Always
        xdg.FieldLayoutSettings.AutoGenerateFields = False
        xdg.FieldLayoutSettings.AutoArrangeCells = AutoArrangeCells.Never
        Dim fl As New FieldLayout
        For Each fe As FormElement In gf.FormElements
            Dim fld As New UnboundField
            Dim xy As XY = Viewer.convertToPoint(fe.position)
            fld.Row = xy._Y
            fld.Column = xy._X
            fld.Label = sFld.longLabel
            Dim w As Int16 = 1
            If sFld.width > 0 Then
                w = sFld.width
            ElseIf sFld.precision > 0 Then
                w = sFld.precision + sFld.decimals
            ElseIf sFld.size > 0 Then
                w = sFld.size
            End If
            If w > 0 Then
                fld.ColumnSpan = w
            End If
            fl.Fields.Add(fld)
        Next
        flc.Add(fl)
        'Load Data
        Dim chld As DbSet(Of Entities5Library.customer) = ParentData.customers
        WorkArea.Add("clntstebllngschdle", chld)
        WorkArea("clntstebllngschdle").Load()
        xdg.DataSource = From x In WorkArea("customer").Local Where x.customer_id = ParentValue
Here is the stack:
at System.Collections.Specialized.ListDictionary.get_Item(Object key)
at System.Collections.Specialized.HybridDictionary.get_Item(Object key)
at System.ComponentModel.PropertyDescriptorCollection.Find(String name, Boolean ignoreCase)
at Infragistics.Windows.DataPresenter.FieldLayout.LayoutPropertyDescriptorProvider.VerifyFieldDescriptors()
at Infragistics.Windows.DataPresenter.VirtualizingDataRecordCellPanel.VerifyPropertyDescriptorProvider()
at Infragistics.Windows.DataPresenter.VirtualizingDataRecordCellPanel.MeasureOverride(Size availableSize)
at System.Windows.FrameworkElement.MeasureCore(Size availableSize)
at System.Windows.UIElement.Measure(Size availableSize)
at MS.Internal.Helper.MeasureElementWithSingleChild(UIElement element, Size constraint)
at System.Windows.Controls.ContentPresenter.MeasureOverride(Size constraint)
at Infragistics.Windows.Controls.CardPanel.MeasureOverride(Size availableSize)
at System.Windows.Controls.Control.MeasureOverride(Size constraint)
at Infragistics.Windows.DataPresenter.DataRecordCellArea.MeasureOverride(Size availableSize)
at System.Windows.Controls.DockPanel.MeasureOverride(Size constraint)
at System.Windows.Controls.Grid.MeasureCell(Int32 cell, Boolean forceInfinityV)
at System.Windows.Controls.Grid.MeasureCellsGroup(Int32 cellsHead, Size referenceSize, Boolean ignoreDesiredSizeU, Boolean forceInfinityV)
at System.Windows.Controls.Grid.MeasureOverride(Size constraint)
at Infragistics.Windows.DataPresenter.RecordPresenter.MeasureOverride(Size availableSize)
at Infragistics.Windows.DataPresenter.GridViewPanelFlat.GenerationCache.GenerateNextElement(Boolean isHeader)
at Infragistics.Windows.DataPresenter.GridViewPanelFlat.GenerationCache.GenerateScrollableRecords()
at Infragistics.Windows.DataPresenter.GridViewPanelFlat.GenerationCache.GenerateAllRecords()
at Infragistics.Windows.DataPresenter.GridViewPanelFlat.MeasureOverride(Size availableSize)
at System.Windows.ContextLayoutManager.UpdateLayout()
at System.Windows.ContextLayoutManager.UpdateLayoutCallback(Object arg)
at System.Windows.Media.MediaContext.InvokeOnRenderCallback.DoWork()
at System.Windows.Media.MediaContext.FireInvokeOnRenderCallbacks()
at System.Windows.Media.MediaContext.RenderMessageHandlerCore(Object resizedCompositionTarget)
at System.Windows.Media.MediaContext.RenderMessageHandler(Object resizedCompositionTarget)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler)
at System.Windows.Threading.DispatcherOperation.InvokeImpl()
at System.Windows.Threading.DispatcherOperation.InvokeInSecurityContext(Object state)
at System.Threading.ExecutionContext.runTryCode(Object userData)
at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData)
at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean ignoreSyncCtx)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Windows.Threading.DispatcherOperation.Invoke()
at System.Windows.Threading.Dispatcher.ProcessQueue()
at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
at System.Windows.Threading.Dispatcher.InvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs)
at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)
at MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG& msg)
at System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame)
at System.Windows.Threading.Dispatcher.PushFrame(DispatcherFrame frame)
at System.Windows.Application.RunDispatcher(Object ignore)
at System.Windows.Application.RunInternal(Window window)
at System.Windows.Application.Run(Window window)
at System.Windows.Application.Run()
at SamproScreenReader.Application.Main() in C:\Users\dnapoleon\documents\visual studio 2010\Projects\SamproScreenReader\SamproScreenReader\obj\x86\Debug\Application.g.vb:line 64
at System.AppDomain._nExecuteAssembly(RuntimeAssembly assembly, String[] args)
at System.AppDomain.ExecuteAssembly(String assemblyFile, Evidence assemblySecurity, String[] args)
at Microsoft.VisualStudio.HostingProcess.HostProc.RunUsersAssembly()
at System.Threading.ThreadHelper.ThreadStart_Context(Object state)
at System.Threading.ThreadHelper.ThreadStart()
