55
express hotfix issue
Hello, I have an application developed with V7.2. I have one xamdatagrid wich allows to add new records. This datagrid is bind to an entityset property within an entity (master/detail) (linq to sql).
Works great in v7.2, no problem whatsoever ! But I installed hotfix 2 and the behaviour of adding a new row apparantly changed somewhat.
When you start to add the first row, the fields are shown directly under the addrowinput FOR THE FIRST ROW ONLY. When I submit the changes
this does not add the row to the database. But when you add two or more rows in the grid, it works. I think this must be a bug.
Does anyone have the same issue ? Workaround ? Thank you !
