245
XamCurrencyInput and string based mask
I am using the XamCurrencyInput to bind to a decimal? value on my ViewModel. I am using the ValueToTextConverter and ValueToDisplayText converters to convert the decimal to string and vice-versa. I need to do this as I have the situation where certain numbers need to be displayed in the following format:
  • 104-02
  • 103-07+
  • 99-29:7
  • 99-28
So the rules I use to create the mask are:
  1. Positions 1 to 3: Optional numerical characters
  2. Position 4: A - (minus) symbol. This does not mean 'minus' - it is equivalent to a decimal place. In my mask, I have it working by 'escaping' it.
  3. Positions 5 to 6: Optional numerical characters
  4. Position 7: Either a + or a : symbol can be placed here.
  5. Position 8: Optional numerical character.
Therefore, I need to have a mask like the following:
nnn\-nn{char:1:+:}n
But this doesn't work. The 'nnn\-nn' part works ok, but no further than that.
I'm not sure whether the mask is not correct, or is incompatible with the Mask property on the control. Please note that I have some success if I insert a [SPACE] character before the {char:1:+:}, but this then leaves the display value with a SPACE in it which I do not want.
Below is my XAML usage. Please note that I have NOT set the DataMode or the DisplayMode to 'Raw'.
<ig:XamCurrencyInput x:Name="PriceBox"
                FontSize="16"
                Grid.Row="1"
                Margin="1,1,-1,2"
                Mask="{Binding Mask}"
                PromptChar=""
                SpinButtonDisplayMode="Always"
                SpinIncrement="{Binding SpinIncrement}"
                TrimFractionalZeros="False"
                Value="{Binding Value}"
                ValueToDisplayTextConverter="{StaticResource MyConverter}"
                ValueToTextConverter="{StaticResource MyConverter}" />
Can anyone please advise how I can get this mask to work or confirm that it is not possible? For now, I will have to use a RegEdit on the ValueConstraint but I'd prefer to get the Mask working.
Slugman
