250
Only select specified cells in row using tab key
Hi all,
I hope, I can describe my question well enough.
I have a XamDataGrid in which only column 4 and 5 can be edited.
Because my users have to change a lot of rows at once, I would like to create the following behaviour:
After editing row 1, column 5 and pressing the tab key, the next selected cell should be row 2, column 4.
Right now they have to jump via tab through column1, 2 and 3 before they can change the values in column 4 and 5.
Is this possible?
If yes, how?
Thanks a lot,
regards
Finchen
  • 138253
    Hello Finchen,
  • 138253
    Hello Finchen,
    Thank you for your post. I have been looking into it and I can suggest you see this forum post:
    http://ko.infragistics.com/community/forums/t/7243.aspx
    where a similar issue like yours is discussed. Please let me know if this helps you or you need further assistance on this matter.
