200
Synchronizing grids with the XamZoombar?
I´m having some problems understanding the synchronization of a couple of charts to the XamZoombar.
This is my xaml:
<Grid Background="{DynamicResource ChartBackground}">
                <Grid.RowDefinitions>
                    <RowDefinition Height="5*"/>
                    <RowDefinition Height="2*"/>
                    <RowDefinition Height="1*"/>
                </Grid.RowDefinitions>
                <ig:XamDataChart x:Name="chart"
                                 CrosshairVisibility="Visible"
                                 UseLayoutRounding="False"
                                 MinHeight="50"
                                 MinWidth="50"
                                 Grid.Row="0"
                                 VerticalAlignment="Stretch"
                                 HorizontalAlignment="Stretch"
                                 HorizontalZoomable="False" VerticalZoomable="False"
                                 VerticalZoombarVisibility="Collapsed"
                                 HorizontalZoombarVisibility="Collapsed"
                                 MouseDoubleClick="chart_MouseDoubleClick"
                                 Foreground="{DynamicResource ChartForeground}"
                                 MouseMove="chart_MouseMove"
                                 SeriesMouseLeftButtonUp="chart_SeriesMouseLeftButtonUp">
                    <ig:SyncManager.SyncSettings>
                        <ig:SyncSettings SyncChannel="syncGroup1"
                                              SynchronizeHorizontally="True"
                                              SynchronizeVertically="False" />
                    </ig:SyncManager.SyncSettings>
                    <ig:XamDataChart.Axes>
                        <ig:CategoryXAxis x:Name="dateXAxis"
                                          ItemsSource="{Binding}"
                                          Label="{}{Date:MM/yyyy}" Visibility="Collapsed">
                            <ig:CategoryXAxis.LabelSettings>
                                <ig:AxisLabelSettings Visibility="Collapsed"/>
                            </ig:CategoryXAxis.LabelSettings>
                        </ig:CategoryXAxis>
                        <ig:NumericYAxis x:Name="priceYAxis">
                            <ig:NumericYAxis.LabelSettings>
                                <ig:AxisLabelSettings Location="OutsideLeft"
                                                      Extent="60" />
                            </ig:NumericYAxis.LabelSettings>
                        </ig:NumericYAxis>
                    </ig:XamDataChart.Axes>
                    <ig:XamDataChart.ContextMenu>
                        <ContextMenu>
                            <ContextMenu.Items>
                                <MenuItem Header="{Binding ViewModel.SelectedSeries}" IsEnabled="False"/>
                                <MenuItem Header="Delete" Click="MenuItem_Click"/>
                            </ContextMenu.Items>
                        </ContextMenu>
                    </ig:XamDataChart.ContextMenu>
                </ig:XamDataChart>
                <ig:XamDataChart x:Name="volChart"
                                 MinHeight="50"
                                 MinWidth="50"
                                 Grid.Row="1"
                                 Foreground="{DynamicResource ChartForeground}">
                        <ig:CategoryXAxis x:Name="commonXAxis"
                                          Label="{}{Date:MM/yyyy}"/>
                        <ig:NumericYAxis x:Name="volumeYAxis">
                                                      Extent="60"/>
                        </ig:NumericYAxis>
                </ig:XamDataChart>
                <ig:XamZoombar x:Name="xmZoombar"
                            Grid.Row="2"
                            Margin="56,0,5,5"
                            Background="Transparent">
                    <ig:XamZoombar.HorizontalPreviewContent>
                        <ig:XamDataChart x:Name="xmPreviewDataChart"
                                      Margin="4,0,4,0"
                                      IsHitTestVisible="False"
                                      IsTabStop="False">
                                <ig:CategoryXAxis x:Name="xmPreviewXAxis" ItemsSource="{Binding}" Label="{}{Date:MM/yyyy}">
                                        <ig:AxisLabelSettings Location="OutsideBottom" HorizontalAlignment="Center" Visibility="Collapsed" />
                                </ig:CategoryXAxis>
                                <ig:NumericYAxis x:Name="xmPreviewYAxis">
                                        <ig:AxisLabelSettings Location="OutsideRight" HorizontalAlignment="Center" Visibility="Collapsed" />
                                </ig:NumericYAxis>
                        </ig:XamDataChart>
                    </ig:XamZoombar.HorizontalPreviewContent>
                </ig:XamZoombar>
In the code behind I do this when loading the control:
        void ChartControl_Loaded(object sender, RoutedEventArgs e)
            if (xmZoombar != null && this.chart != null)
                Binding binding = new Binding
                    Source = this.chart,
                    Path = new PropertyPath("HorizontalZoombar.Range"),
                    Mode = BindingMode.TwoWay
                xmZoombar.SetBinding(XamZoombar.RangeProperty, binding);
                xmZoombar.Range = new Range { Minimum = 0.3, Maximum = 1 };
This is how I add my series:
private void AddToChart(Series series)
            LineSeries newSer = new LineSeries();
            newSer.MarkerType = MarkerType.None;
            newSer.ItemsSource = series.Data;
            newSer.ValueMemberPath = "Price";
            newSer.Title = series.Symbol;
            newSer.XAxis = commonXAxis;
            newSer.YAxis = priceYAxis;
            chart.Series.Add(newSer);
            ColumnSeries volSer = new ColumnSeries();
            volSer.MarkerType = MarkerType.None;
            volSer.ItemsSource = series.Data;
            volSer.ValueMemberPath = "Volume";
            volSer.Title = series.Symbol + "Volume";
            volSer.XAxis = commonXAxis;
            volSer.YAxis = volumeYAxis;
            volSer.XAxis.ItemsSource = series.Data;
            volChart.Series.Add(volSer);
            LineSeries previewSeries = new LineSeries();
            previewSeries.MarkerType = MarkerType.None;
            previewSeries.ItemsSource = series.Data;
            previewSeries.ValueMemberPath = "Price";
            previewSeries.Title = series.Symbol;
            previewSeries.XAxis = xmPreviewXAxis;
            previewSeries.YAxis = xmPreviewYAxis;
            previewSeries.XAxis.ItemsSource = series.Data;
            xmPreviewDataChart.Series.Add(previewSeries);
The issues I´m having is that only one of the charts follows the zoombar while the other just sits there.
What am I missing?
I would also like to be able to set the range of the zoombar to a date range but due to the limits of the DateTimeAxis all of the series need the same number of points so I´m stuck with categoryAxis.
  • 138253
    I am just checking if you got this worked out or you still require any assistance or clarification on the matter.
  • 138253
    Thank you for your post. I have been looking into it and I created a sample project for you using your code with a little modification. Basically I set the line chart’s HorizontalZoomable Property to True in XAML, so the binding to the Zoom Bar could be initialized and then I set it back to false in code.  Please let me know if this helps you or you need further assistance on this matter.
    XamDataChartsZoomBarSync.zip
