I came a problem when refreshing filter in a xamdatagrid.
If there are 5 rows in my grid, and i selected the first 3 rows, the 3rd row is active. Then, i changed the filter condition which will make row 1, 3, 5 disappear. Now, i want to refresh selection and active row to make the row 2 is selected only and no row is active.
However, the current xamdatagrid's behavior is even after filter updates, the active row (row 3) doesn't disappear until i make another row active. Also, the SelectedItemsChanged doesn't trigger and selecteditems still has 3 rows before i select another row. That's no good. Is there any setting to change the behavior quickly? Or i must programmatically set the selected and active record when filter updating?
Thanks.
Thank you for your post. I have been looking into it and would you please attach a sample application that shows your scenario or give me a code snip with the events that you are handling in order to reproduce it and provide you with more accurate assistance ?
