By default, the xamDataGrid creates child records for a property that is of type IEnumerable. Instead, I want to ToString() representation of my collection to be represented in a single field. I tried using the following CellValuePresenter on the field definition:
<Style x:Key="SimpleCollectionStyle" TargetType="{x:Type igDP:CellValuePresenter}"> <Setter Property="Template"> <Setter.Value> <ControlTemplate TargetType="{x:Type igDP:CellValuePresenter}"> <Border BorderBrush="{StaticResource DataGridCellOuterBorder}" BorderThickness="1,0,0,0"> <TextBlock Text="{Binding DataItem}" Margin="10,5,3,5" /> </Border> </ControlTemplate> </Setter.Value> </Setter> </Style>
But it did not work.
No, thank yuo.
Hello Knji,
Sincerely,
Krasimir
Developer Support Engineer
www.infragistics.com/support
Thank you for your post. I have been looking into the appearance that you are trying to achieve and I can suggest using UnboundField, instead of Field. When using Field, its DataType, takes the type of the property, to which the field is bound and if that type is IEnumerable, it displays a hierarchy. The DataType of the UnboundField, by default is string and the ToString will be displayed in the cell of that field, when it is bound to a IEnumerable. Also I can suggest changing the Binding of the Text of the TextBlock, since binding to the DataItem property, it will display the ToString of the object used as data for the record. You can use RelativeSource and bind the Text to the value of the cell. I have created a sample application for you, that shows how you can implement the approach I have described.
Please let me know if you need any further assistance on the matter.
