295
Right click on header to select column
We're trying to figure out which column was selected when the user right clicks.
We tried the following:
        private void _xamDataGrid_MouseRightButtonDown(object sender, MouseButtonEventArgs e)
            DataRecordPresenter rec = Infragistics.Windows.Utilities.GetAncestorFromType(e.OriginalSource as DependencyObject, typeof(DataRecordPresenter), false) as DataRecordPresenter;
            if (rec != null)
                if(rec.Record.RecordType.ToString() == "HeaderRecord")
			// get name of column...
But can't seem to get the column name.  Can you help please?
Jon
  • 35319
    Hello Jon,
  • 35319
    I have been looking into your question and I achieved the functionality that you are looking for by programmatically sorting :
    http://help.infragistics.com/Help/NetAdvantage/WPF/2012.1/CLR4.0/html/xamDataPresenter_Programmatically_Sort_and_Group_Fields.html
    You can try the following code :
         private void xamDataPresenter1_PreviewMouseRightButtonDown(object sender, MouseButtonEventArgs e)
                var labelPresenter = Infragistics.Windows.Utilities.GetAncestorFromType(e.OriginalSource as DependencyObject, typeof(LabelPresenter), true);
                FieldSortDescription desSort = new FieldSortDescription();
                desSort.Direction = System.ComponentModel.ListSortDirection.Descending;
                FieldSortDescription ascSort = new FieldSortDescription();
                ascSort.Direction = System.ComponentModel.ListSortDirection.Ascending;
                string clickedFieldName = ((DataItemPresenter)labelPresenter).Field.Name;
                ascSort.FieldName = desSort.FieldName = clickedFieldName;
                if (((DataItemPresenter)labelPresenter).Field.SortStatus == Infragistics.Windows.Controls.SortStatus.Descending)
                    this.xamDataGrid1.FieldLayouts[0].SortedFields.Clear();
                    xamDataGrid1.FieldLayouts[0].SortedFields.Add(ascSort);
                else if (((DataItemPresenter)labelPresenter).Field.SortStatus == Infragistics.Windows.Controls.SortStatus.Ascending)
                    xamDataGrid1.FieldLayouts[0].SortedFields.Add(desSort);
                else
    Please let me know if you need any further assistance on this matter.
