in my DataContext of the IGXmalDataChart, I have 3 observableCollection:
ObservableCollection<DateTime> DT;
ObservableCollection<float> Pen1Data;
ObservableCollection<float> Pen2Data;
How can I bound those to show on the xAxis for time, and yAxis for Pen1Data and Pen2Data? I used ItemsSource={Binding DT}, not working.
Thanks!
If the above suggestion helped you solve your issue please verify the thread as answered so other users may take better advantage of it.
Hello Joan,
I have been looking into your enquiry and I am not really sure what your requirement is here. Usually the XamDataChart uses its Series classes: http://help.infragistics.com/NetAdvantage/WPF/2012.2/CLR4.0/?page=xamDataChart_Series_Types.html to visualize data and based on the chosen series the appropriate axes are used: http://help.infragistics.com/NetAdvantage/WPF/2012.2/CLR4.0/?page=xamDataChart_Series_Requirements.html . I can also suggest you go through the online documentation for the XamDataChart in order to get a better understanding of its design: http://help.infragistics.com/NetAdvantage/WPF/2012.2/CLR4.0/?page=xamDataChart_xamDataChart.html also you can look at the sample which come with their own source code: http://ko.infragistics.com/products/silverlight/data-chart/ to see how the XamDataChart can be used.
Please let me know if you require any further clarification on the matter, or if I have misunderstood you in any way
