840
GroupByAreaMulti fails to open with default template
The default template for GroupByAreaMulti control is causing the GroupByArea expander to flicker (expand and close) when I try to expand it. I am using the default control template that is generated in Blend.  If I remove the template, the expander works fine.
  • 35319
  • 35319
    I have been looking into your post and you can find the default styles for the XamDataGrid in :
    C:\Program Files (x86)\Infragistics\NetAdvantage 2012.2\WPF\DefaultStyles\DataPresenter\DataPresent erGeneric.xaml
    C:\Program Files (x86)\Infragistics\NetAdvantage 2012.2\WPF\DefaultStyles\DataPresenter\ DataPresenterGeneric_Express.xaml
    C:\Program Files (x86)\Infragistics\NetAdvantage 2012.2\WPF\DefaultStyles\DataPresenter\ DataPresenterGeneric_Brushes.xaml
    I am attaching a sample application(XamDataGridSample.zip) where I have applied the default style for ‘GroupByAreaMulti’ and everything goes right.
    If you need any further assistance on this matter, feel free to ask.
