I want to disable the edit mode of a row but still the row can be used to select and do something (i.e) just the edit mode of a row should be removed. Browsed in IG forums and didn't get any solution for this. Is there way to do this ?
Thank you
Hello Yanko,
Thanks for your response. I will be happy if it is possible. As of now, let me use EditModeStated event to handle this.
Hi Kumaran,
Currently this is no other way to make a particular record read-only.
Thanks for your response. Just want to conform, is there any other way to do this ?
Hello Kumaran,
Thank you for your feedback. This is the best approach which I can suggest you. You can loop through your records collection and on some criteria to cancel the event.
If you have any other questions on this matter, feel free to ask.
