140
KeyNotFoundException after floating the only contentpane in XamDockManager
we have a problem with the dockmanager. After floating the last tab inside the dockmanager, and adding a new contentpane via prism, which is docked by default, we get a
The region manager does not contain the workspace region.
After googling for a while, I found that the TabGroupPane gets recycled. Is that the case? If yes, how to prevent this (except adding a dummy tab control)?
Thanks in advance
Christian
  • 138253
    Hello Christian,
    Thank you for your post. I have been looking into it and I believe that the best approach is to add dummy tab control, but if I think of another possible solution for you I will let you know.
