I have a scatterseries chart bound to a items collection. We calculate our own errors, so for errorbars I set the verticalCalculator to the DataCalculator and set the correct items source and ValueMemberPath. This all seems to work correctly when I toggle the errors they show up with the correct values.
The problem that the y Axis does not change its scale to account for the top of the error bar, so I end up with clipping. How do I get the yAxis to update when I turn on the error bars?
private void AddErrorBars(ScatterSeries scatterSeries) { var errorBarSettings = new ScatterErrorBarSettings { EnableErrorBarsHorizontal = EnableErrorBars.None, EnableErrorBarsVertical = ShowY1ErrorBars ? EnableErrorBars.Both : EnableErrorBars.None, HorizontalErrorBarCapLength = 10, HorizontalStroke = scatterSeries.Brush, HorizontalStrokeThickness = 2, VerticalStroke = scatterSeries.Brush, VerticalErrorBarCapLength = 10, VerticalStrokeThickness = 2, VerticalCalculator = new DataCalculator { ItemsSource = scatterSeries.ItemsSource, ValueMemberPath = "DataError2" }, }; scatterSeries.ErrorBarSettings = errorBarSettings; }
I am just checking if you got this worked out or you still require any assistance or clarification on the matter.
Thank you for your post. I have been looking into it, but since this is not a known issue I cannot be completely sure what can cause this behavior, so could you please send an isolated sample project, where the issue is reproduced, so I can investigate it further for you.
