360
XamDateTimeSlider Binding: Whats wrong!?
Hello, verry simple example. Just a slider, a label for visualization of my property and three properties in the code behind. The properties all implement iNotifyPropChanged.
<StackPanel Orientation="Vertical">
    <ig:XamDateTimeSlider MaxValue="{Binding MaxDate}" MinValue="{Binding MinDate}" Value="{Binding ThisDate}" />
    <Label Content="{Binding ThisDate}" />
</StackPanel>
This does NOT write the Value back to my "Today" Property. The Min and May Dates are set properly.
If i try this
<ig:XamDateTimeSlider MaxValue="{Binding MaxDate}" MinValue="{Binding MinDate}" >
    <ig:XamDateTimeSlider.Thumb>
        <ig:XamSliderDateTimeThumb Value="{Binding ThisDate}" />
    </ig:XamDateTimeSlider.Thumb>
</ig:XamDateTimeSlider>
it does not work either. If i have a look into the thumbs value using the debugger, i can see that the value is changed. However, neither the slider nor the thumb seems to write back to the property :(
