I have so UnboundFields and have a have overriden so that there is a togglebuttion with a contextmenu. When I right click, on one of the UnboundField lables, it immediately moves to the end of the list. Is there some way to disable this. I have tried capturing the ButtonDown and PreviewButtonDown
I am just checking if you got this worked out or you still require any assistance or clarification on the matter.
I created a sample project for you using your code and everything seems to work ok on my side. If the sample doesn’t satisfies all your needs feel free to modify it, so it reproduces your behavior and send it back to me for further investigation.
I have the following XAML:
<Style x:Key="LabelPresenterBroker" TargetType="{x:Type igDP:LabelPresenter}" BasedOn="{StaticResource {x:Type igDP:LabelPresenter}}"> <Setter Property="Template"> <Setter.Value> <ControlTemplate> <ToggleButton Name="tb" Content="{Binding Content, RelativeSource={RelativeSource TemplatedParent}}" Height="23" Click="AssignToBatch_ToggleButton_Click" > <ToggleButton.ContextMenu> <ContextMenu> <MenuItem Click="AssignToBatch_MenuItem_Click"> <MenuItem.Icon> <StackPanel Orientation="Horizontal"> <Image Source="/Fox.UI.Resource;component/Images/arrow_right.png" /> <Label Content="Assign to Batch" VerticalAlignment="Center" /> </StackPanel> </MenuItem.Icon> </MenuItem> <MenuItem Click="Sort_MenuItem_Click"> <MenuItem.Icon> <StackPanel Orientation="Horizontal"> <Image Source="/Fox.UI.Resource;component/Images/arrow_right.png" /> <Label Content="Sort" VerticalAlignment="Center" /> </StackPanel> </MenuItem.Icon> </MenuItem> </ContextMenu> </ToggleButton.ContextMenu> </ToggleButton> </ControlTemplate> </Setter.Value> </Setter>
When I click, I have no problem, the click event works fine. WHen I right click for the context menu first time,
I end up at the sent of the records.
Thank you for your post. I have been looking into it, but it seems like that I am missing something in your scenario, so if this is still an issue for you, could you please send an isolated sample project, where the issue is reproduced, so I can investigate it further for you.
