Hi we're using the Metro Theme for our docking manager because we like the flat look to it, however the pane separators and title areas are huge and we would like to shrink those down to something more standard for a desktop application. I've look around, but I've not seen where I can specify the width for the pane edges or the height for the title area. Any help would be appreciated.
Thank you for your feedback.
If you need any further assistance on this matter, do not hesitate to ask.
Perfect. Thanks.
The elements that you are looking for are ‘DockedPaneSplitter’ and ‘PaneHeaderPresenter’. You can find the default styles for them in :
C:\Program Files (x86)\Infragistics\NetAdvantage 2012.2\WPF\DefaultStyles\DockManager
If you need any further assistance on this matter, feel free to ask.
I've not applied anything yet. My question is in regards to where can I set that information. I've looked around and I'm not sure what control style to modify to begin with. I would like to know where the "ContentPaneBorderWidth" (or whatever name it has) property resides.
Thank you for your post. I have been looking into your question and it seems that you have tried to apply styles and when you are using a theme they are not applied. In order to fix your issue I can suggest look into the following forum thread :
http://ko.infragistics.com/community/blogs/andrew_smith/archive/2009/12/09/common-style-issues-when-using-the-theme-property.aspx
