I want to change the Foreground color of each date in MonthView.
Can you pls point me to the part of the template to do so?
in MonthView when I change the ColorScheme to Whitecolor , all my days turn white and it becomes unusable.
Quick fix I found is to iterate thru all TextBlocks and change the forecolor but I would prefer to change the template to get this done.
Hello Rajesh,
Thank you for your post. I have been looking into it and I can suggest you create a Style for the ScheduleDateRangePresenter and add an EventSetter for the Loaded event like this:
<Style TargetType="{x:Type igPrim:ScheduleDateRangePresenter}"> <EventSetter Event="Loaded" Handler="ScheduleDateRangePresenter_Loaded"/> </Style>
And add the following handler in the code behind:
private void ScheduleDateRangePresenter_Loaded(object sender, RoutedEventArgs e) { (sender as ScheduleDateRangePresenter).Foreground = Brushes.Red; }
Please let me know if this helps you or you need further assistance on this matter.
