470
IComparer - Pass DataRecord instead of CellValue?
Hello -- I'm using the XamDataGrid, and I need to do a custom sort based on a property from the DataRecord.DataItem, not just the cellValue of the column I'm sorting on. Is there a way to access or pass the DataRecord to IComparer?
column1 column2 column3 prop1 ---- record 1
column1 column2 column3 prop1 ---- record 2
column1 column2 column3 prop1 ---- record n
I would like to custom sort on column 2 (when column 2 is grouped) using the value of prop1.  Thanks!
