maybe my question is really simple, but I just do not get it and I googled a lot.
I have a xamDataCard control with only one DataCard. I want to bind another control to one field of that DataCard, which holds a numeric value. (More precise it is a RadialGaugeNeedle and I want to bind the Value of it to that value of the one field of the DataCard. But it does not really matter, could be any other control, I think I just do not know how to write the Path=??? correct.)
Here is my DataCard so far:
<igDP:XamDataCards Grid.Row="2" HorizontalAlignment="Left" Margin="12,12,0,0" Name="xamDataCards1" VerticalAlignment="Top" DataSource="{Binding ElementName=xamMultiColumnComboEditor1, Path=SelectedItems}" > <igDP:XamDataCards.FieldLayouts> <igDP:FieldLayout > <igDP:FieldLayout.Fields> <igDP:Field Name="Name" Label="Name" /> <igDP:Field Name="Volume" Label="Volume" /> <igDP:Field Name="TargetWeight" Label="Target Weight" /> <igDP:Field Name="ImageUrl" Label="Image" /> <igDP:UnboundField Name ="RealWeight" Label="Real Weight" /> </igDP:FieldLayout.Fields> </igDP:FieldLayout> </igDP:XamDataCards.FieldLayouts> </igDP:XamDataCards>
I want to be able to edit the "Real Weight" field and have the number bound to GaugeNeedle or whatever. So:
<ig:RadialGaugeNeedle Value="{Binding ElementName=xamDataCards1, Path=???, FallbackValue=0}" />
How do I have to set the Path, that is my big question? (Or do I have to write the ElementName also in a different way?) In fake pseudo code I want to write something like Path=Card[0].Field["RealWeight"].Value or more grid-like Path=Row[0].Column["RealWeight"].Value
I think you get my point. :-)
Thank you very much.
I would appreciate it when you could post the solution for the xamDataGrid and the xamDataPresenter, too. I mean, how to bind something to a cell-value of a xamDataGrid
Thanks again.
Hello Stefan,
thank you for your answer. It works and is really stupid simple, so sorry for asking... At least I am happy that it works the way I expected it.
I think the Problem was, that I believe to much in IntelliSense, because when I type Path=Records[0]. it does not offer me Cells (Records was offered). Actually when I just write it, Cells is underlined and the message is "Cannot resolve property 'Cells' in data context of type Infragistics.Windows.DataPresenter.Records"
But anyway, when I ignore it, it runs, so thanks again.
Thank you for your post. I have been looking into it and I can suggest you set the Path like this:
Path=Records[0].Cells[TargetWeight].Value
The Path for the XamDataGrid and XamDataPresenter is the same. Please let me now if his helps you or you need further assistance on this matter.
