Is it possible to format cell based on the values of another cell ? I know I can specify StyleScope=Row to apply rule to all cells of the row.
Ed
Yanko,
Thank you very much for the sample, it resolved my problem.
Hello Ed,
Thank you for your feedback. I have been looking into your question and another approach that I can suggest you is to define a style for the ‘CellControl’ and set the ‘Background’ property using converter. I am attaching a sample application(CustomConditionalFormatConverter.zip) that shows this approach.
If you need any further assistance on this matter, feel free to ask.
Thank you for the sample. As far as I understand, there is no XAML-only solution for such type of conditional formatting, correct ?
Hello Sentil,
Thank you for your post. I have created a sample application(XamGridCustomConditionalFormat.zip) that shows the desired functionality. The background of the cells in the first columns depends on the value of the cells in the second one.
