I must be doing something wrong. I have a WPF application, have a xamMonthView, I used the online example for single instance. When I run my application, I can see the scroll back, but the area were the calendar should be is blank, if I scroll the area, it shows the dates, so the data is loading, see below for the assignments. What is also strange is if I try to render just the calendar unattached, the same thing happens
<ig:XamMonthView x:Name="calCallBacks" Height="334" Width="565"> <ig:XamMonthView.DataManager> <ig:XamScheduleDataManager CurrentUserId="1" x:Name="dataManager"> <ig:XamScheduleDataManager.CalendarGroups> <ig:CalendarGroup InitialCalendarIds="1"/> </ig:XamScheduleDataManager.CalendarGroups> <ig:XamScheduleDataManager.DataConnector> <ig:ListScheduleDataConnector ResourceItemsSource="{Binding CallResponse.CalControl_Resources}" ResourceCalendarItemsSource="{Binding CallResponse.CalControl_Calendar_Resources}" AppointmentItemsSource="{Binding CallResponse.Marketing_Upcoming_CallBacks_Calendar}"/> </ig:XamScheduleDataManager.DataConnector> </ig:XamScheduleDataManager> </ig:XamMonthView.DataManager> </ig:XamMonthView>
I can suggest you look into the Output, while in Debug mode, in order to check if there are any Binding errors.
To test, I have changed to ObservableCollection, tried doing the binding on the XAML, still the blank issue, nothing is rendered except a scroll bar. Tried binding through code behind as well, same issue
Still having the same issue. It must be something to do with my binding, what objects can I bind to, I am currently binding to a CollectionViewSource, is that not acceptable? If not, I can run it through code behind like you did
I created a sample project for you where I used XamMonthView and everything seems to work ok on my side.
