I would like to know is there a way I can use stlye triggers to set Record.IsSelected based on a condition in a record set?
After looking at this posting I figured out how to pass in the entire datarecord and set is selected:
http://ko.infragistics.com/community/forums/t/69484.aspx
Thanks for your help.
Thank you for your feedback. I am glad that you resolved your issue and I believe that other community members may benefit from this as well. Also as I said before your are not able to use a Converter and Style for the DataRecordPresenter in order to achive this functionality, becasue the IsSelected Property is set internally via code.
Thanks again.
I figured out a way to do it however, I would like to know is there a way I can use a converter to do the following code:
foreach (Record r in xamDataGrid1.Records) { DataRecord dr = r as DataRecord; if (dr.Cells["Sex"].Value.ToString() == "F") { r.IsSelected = true; } }
I've attached an update sample project, to show my scenerio.
The problem I have is when I load a datagrid I want to set selected records based on a criteria, however I'm having trouble trying to do so using MVVM. I've attached a sample project were I was trying to preselect records based on sex when the datagrid loads.
Thank you for your post. I have been looking into it and I can say that you are not able to set the IsSelected Property of the DataRecordPresenter via Style, because this Property is set internally by code.
Hope this helps you.
