1020
xamSchedule / XamScheduleDataManager
I have a question for datamanager.DisplayActivityDialog method.
I would like the dialog remains open even if I switch to the other TabItem:
        <igWPF:XamTabControl>
            <igWPF:TabItemEx Header="First">
                <ig:XamOutlookCalendarView HorizontalAlignment="Left"
                                           VerticalAlignment="Top"
                                           DataManager="{Binding DataManager}" />
            </igWPF:TabItemEx>
            <igWPF:TabItemEx Header="Second" />
        </igWPF:XamTabControl>
I use a derivative of ScheduleDialogFactory (MyDialogFactory)
 _datamanager.DialogFactory = new MyDialogFactory
Public Overrides Function CreateActivityDialog(container As FrameworkElement,… ) As FrameworkElement
Experiments with the parameters ‘container’ have had no success.
Return MyBase.CreateActivityDialog(container,dataManager,activity,allowModifications,allowRemove)
Thank you
  • 54937
    Verified Answer
    The dialogs are closed when the Unloaded event of the XamScheduleDataManager is invoked. I see you are binding to a DataManager property. If the xamScheduleDataManager isn't parented within some visual element it will be hosted in the control that is referencing it - the xamOutlookCalendarView. So one way to do what you want is to define the xamScheduleDataManager in the visual tree outside the XamTabControl.
