I have the below code which triggers when a record in the datapresenter is activated. Basically all it does is grab the selected data and use it in some other routines. I would like to move code out of the record activated event and into a double click event.
Private Sub XamDataPresenter1_RecordActivated(ByVal sender As Object, ByVal e As Infragistics.Windows.DataPresenter.Events.RecordActivatedEventArgs) Handles XamDataPresenter1.RecordActivated
If TypeOf e.Record Is FilterRecord Then Exit Sub End If
' Check to make sure the selected Record is a DataRecord If TypeOf e.Record Is DataRecord Then
' Cast the record passed in as a DataRecord Dim myRecord As DataRecord = CType(e.Record, DataRecord)
If IsNothing(myRecord.Cells(0).Value) = False Then lblclient.Content = myRecord.Cells(0).Value.ToString()
displayclientprograms()
'get assessment history getclientassessmenthistory()
End If
End If End Sub
How do i do this?
Hi Pfechner,
If the idea is to double click a record and then execute some logic with the data recod you could try something like this:
private void xdp_MouseDoubleClick_1(object sender, MouseButtonEventArgs e)
var valueEditor = Infragistics.Windows.Utilities.GetAncestorFromType((DependencyObject)e.OriginalSource, typeof(ValueEditor), true);
if (valueEditor != null)
if (((ValueEditor)valueEditor).DataContext is DataRecord)
DataRecord dr = ((ValueEditor)valueEditor).DataContext as DataRecord;
Please let me know if this works for you or if I misunderstood you.
Slavi
