i want to save the layout of the dockmanager whenever it is changed. (Panes are moved, pinned, closed etc.)
Which event(s) can i use to trigger saving the layout?
cheers,
kmb
Ok everything worked fine. Thank you!
Hello KarlMichael,
Thank you for your reply. Please let me know if you need any further assistance on the matter.
Sincerely,
Krasimir
Developer Support Engineer
www.infragistics.com/support
No thanks, i guess this will do it. I just didn't get back to this issue yet.
Thank you for your post. I have been looking into it I can suggest using the Closed and ExecutedCommand events of the ContentPane and also the PaneDragEnd event of the XamDockManager. You can create a style without key for the ContentPane and handle the events there, in order to be able to use one event handlers for each ContentPanes inside the XamDockManager. You can use the ExecutedCommad event of the ContentPane to detect pinning and unpinning of the ContentePanes and the PaneDragEnd event to handle the re-ordering of the panes by dragging them. I have created a sample application for you, that show how you can implement the approach I have suggested.
